Old 02-06-2015, 09:08 AM   #1
RoamingEngineer's Avatar
Aluminum Rims
Anyone here with a 390bh that has upgraded their rims from steel to aluminum? I'm considering doing this and have got a quote from Freightliner in Gaffney SC for ~$3000.00.
I'm wondering what people have paid.
Also, do you have all aluminum rims on the rear or is it just the outsides that they change to aluminum?
RoamingEngineer is offline   Reply With Quote
Old 02-06-2015, 01:22 PM   #2
Campin Cajun's Avatar
Interested because I would like to do the same
I know for sure one other member did but I cannot remember who.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 02-06-2015, 04:35 PM   #3
dan-nickie's Avatar
Phil57 should be along shortly to fill you in.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 02-06-2015, 04:43 PM   #4
JTN8's Avatar
I've looked into it also. I've heard our studs may not be long enough and some mods may need to be done but not 100% sure about that. I'd be interested in total cost and if they would buy back the simulators.... If not I'm sure we could sell them on E-Bay
Jason
Old 02-06-2015, 05:33 PM   #5
Back in my old days working for a trucking company I was taught not to mix the steel and aluminum wheels. The aluminum wheels were a little different in size even if the tires were the same size. We ran all aluminum wheels on the tractors and steel on the trailers. Hard to balance the aluminum/steel combo together. If you can't swing all aluminum go with the simulators, or just save your pocket change for all aluminum.
______________
MKClark
MKClark is offline   Reply With Quote
Old 02-06-2015, 05:39 PM   #6
tmmar's Avatar
My '14 came with 4 aluminum wheels an 2 steel wheels on the inside rear tires. All of the Berkshires have this configuration.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 02-06-2015, 07:38 PM   #7
JTN8's Avatar
My old class A was the same combo of 4 aluminum and 2 steel inside of the duals... Never had an issue with the ride. As I've been looking to upgrade my berk, Freightliner recommended the same combo...
Jason
Old 02-06-2015, 09:05 PM   #8
I upgraded mine. I was quoted 1500.00 by FL Gaffney. I should have jumped on it. I ended up getting rims at a local shop. 4 rims mounted and balanced for 1325.00 with my 4 steel rims in trade. You then need to get all the extras. Lug covers be careful what you get as even some stainless will rust quickly. I got plastic and they look good. You then need front hub covers. These can be aftermarket and are 5 lug. Be careful to match the brightness so they match the rim. In the back rims you need to order the brackets that allow the hub screw to screw into. I most likely have the part numbers someplace I will check. On the back the brackets are easy to install. A 5 minute job. The back hub cover you buy at a FL dealership and they most likely will need to order it. Your vin number will do you no good you will need a vin number for a MH that came with the aluminum rims. So on the back you need the brackets the hub cover and the long bolt with the logo chrome end.
Total I had around 1700.00 in it. I will look for the part numbers.
Also no way Gaffney did that quote correctly. I would double check on that. They quoted me 1500.00 in 2012.
Old 02-06-2015, 09:08 PM   #9
Also the aftermarket hub covers did not work for me. They are much cheaper but the lugs are to short. I tried several at several different chrome shops and none fit.
Old 02-06-2015, 09:17 PM   #10
Here is the part numbers Click image for larger version
Name:	ImageUploadedByForest River Forums1423279013.254293.jpg
