Old 01-30-2015, 09:47 AM   #1
KennyGolub's Avatar
Another chassis battery question
I've read several threads on chassis battery and charging. Seems some are supposed to charge when connected to shore power and others don't.
Does any one know for sure about the Berkshire? I leave it plugged in to 120v 24/7, but do I need to add a trickle charger for the chassis batteries ?
Thanks,
Ken
KennyGolub is offline   Reply With Quote
Old 01-30-2015, 10:01 AM   #2
It's easy to find out with a voltmeter if your convertor is charging your chassis battery. Turn off everything you can that runs on 12 volts. With the coach on shore power and the battery disconnect on (batteries supplying power to the coach), check the voltage across the chassis battery. If you have at least 13.2 volts, and maybe up to 13.7 volts, the convertor is charging the battery. If you have about 12.5 volts, the battery is fully charged but is not being charged by the convertor. It easy to see what's happening if you read the chassis battery voltage while someone else connects the shore power. You would see the chassis battery voltage increase as the convertor starts charging it.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 01-30-2015, 10:28 AM   #3
bubbles's Avatar
I believe your MH is like all FR MH's I've tested. When on shore power coach batteries have priority and when driving chassis batteries have priority but all batteries are charged with either configuration. Of course this is predicated upon correct interconnects and functioning hardware.
Old 01-30-2015, 11:14 AM   #4
Campin Cajun's Avatar
I was told by Frieghtliner that only the house batteries charge while on shore power. I tend to believe it because when I first start the engine after it's been sitting awhile I get the low battery warning.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-30-2015, 11:46 AM   #5
The following excerpts were taking from Intellitec & RV Custom Product Battery Control Center Manuals, describes the associated charging circuit operations.
I'm not sure if these BCCs are used on a DP, but a quick email to either
manufacture could provide further information
Intellitec
BATTERY CONTROL CENTER - MINI GAS
Charging Circuit
The charging circuit, (which utilizes an isolator solenoid to connect the two batteries
together for charging) will charge both batteries if either battery is being charged.
It operates by sensing the voltage on the Main and Auxiliary batteries. If either
voltage goes above 13.3 volts (the minimum necessary to fully charge a battery)
for more than 14 seconds, the isolator solenoid will pull in, charging both batteries.
If, while the ignition is on, the voltage falls below 12 volts for more than 4 seconds,
the isolator relay will open keeping all of the alternatorís outputs available for the
chassis functions. If the ignition is off and the auxiliary battery voltage should drop
below 12.8 volts (voltage of a fully charged battery) for 4 seconds, the isolator
relay will open, preventing the coach loads from discharging the Main battery.
RV Custom Products
SDC-I07A Battery Control Center
Interconnect Relay
Control electronics on the circuit board parallels the coach and chassis batteries with the
interconnect relay. In addition, the batteries can be paralleled with a momentary pushbutton
switch on the driver's console that applies +12vdc to P3-1.
For the purpose of charging the coach and chassis batteries, power for the control
electronics is obtained from the ignition switch and coach battery through diodes D1 and
D2. Underway, when the charging source is the engine generator, +13.2vdc on the
ignition line triggers the electronics. After a 15 sec. delay, the interconnect relay closes,
paralleling the batteries. Should the battery voltage go below 12.7vdc, the interconnect
relay will open after around a 15 sec. delay. When the vehicle is parked and on shore
power, when the converter brings the coach battery up to +13.2vdc, the interconnect relay
will close after the 15 sec delay, charging the chassis battery as well. As before, the relay
will open when the battery voltage goes below 12.7vdc.
mbtelguy is offline   Reply With Quote
Old 01-30-2015, 11:56 AM   #6
silver's Avatar
I have been told that the coach batteries have priority, Once fully charged you will charge the chassis battery. The switch on the dash that ties the batteries together, I forget the label on it but when the chassis battery is charging you will see the light on faintly.
Regarding low battery when starting the coach that is due to the energy required to heat the manifold as well as run the starter. It is not because the battery was not fully charged.
Rather than leaving the coach plugged in all winter I use a three stage charger/maintainer from Harbor Freight. Item Number 99857 on sale for $19.99. I have one on each bank of batteries. What is nice is they never have to come off. Stay connected all summer and just plug in in the fall. Work great.
silver is offline   Reply With Quote
Old 01-30-2015, 11:57 AM   #7
I'm not sure the battery set ups we have are considered auxiliary. We have dedicated house and dedicated chassis batteries. It would be nice if we could get something like you posted but I don't believe we have it now.
Old 01-30-2015, 12:08 PM   #8
bubbles's Avatar
All MH's have dedicated batteries (coach/chassis) as you say. The emergency start switch ties the coach batteries to the chassis for starting the engine when the chassis battery is to low. If you have such a switch then chances are all the batteries are charged as previously stated. Best advice then, contact FR (MH manufacturer), not Freightliner for clarity.
Old 01-30-2015, 12:10 PM   #9
I just spoke to a tech on the diesel pusher help line (574-522-1368) on another topic, and he did confirm to me that the chassis batteries are charged when connected to shore power. The house batteries come first in the charging sequence, and then the chassis batteries come second. You can tell when that is happening by looking at the Aux Start button on the dash. When it has a low glow, and blinks, the chassis batteries are charging. Hope that helps.
2012 Berkshire 360-FWS
2003 Jeep Liberty Dinghy
Roadmaster All-Terrain
BrakeBuddy
hawk10eye is offline   Reply With Quote
Old 01-30-2015, 12:46 PM   #10
JTN8's Avatar
My 2014 Berkshire does indeed charge both sets of batteries while plugged into shore power and from the alternator. I know this because my chassis batteries kept dying on me when plugged in. My dealer told me that shore power does not charge them. I called Randy at FR. And he said they do! He called my dealer and told them what to check and how to fix it. Here is what I was told.
On shore power, your house batteries charge first then when full, there is a switch (mine was bad) that closes the charge to the house and charges your chassis batteries. You know this is happening because your aux switch will light up dim and flash when charging your chassis batteries while on shore power.
While driving down the road, your alternator will do the same thing only charging your chassis batteries first.
Again this was all coming from Randy and his guys at FR. Since my switch was replaced, I've never had dead chassis batteries again. There are still many things in our coach that run off the chassis batteries that we all use while camping or living in the coach and if the shore power didn't charge them, we'd all have dead batteries more often...
Jasin
battery
