Old 05-16-2018, 02:48 PM   #1
edgewant's Avatar
Another close call with a Michelin tire
I’m beginning to question the quality of Michelin RV tires.
Attached picture shows a rupture of a bulge between the carcass and the sidewall compound. The bulge blew while maneuvering around a truck stop at low speed but the tire remained inflated. Stopped just off the property of the truck stop and had a mobile tire service come and change the tire. Technician said probably caused by impact.
This is the second XZE2 tire in the same position to develop a sidewall defect. Both were less than 3 years old by date code.
Not sure Michelin will do a thing since they would not on the first which was a much milder bulge. Click image for larger version
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-16-2018, 03:16 PM   #2
SeaDog's Avatar
If it is on the outside dual and same position you may be turning to short to curbs and catching the sidewall JMHO
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-16-2018, 03:32 PM   #3
edgewant's Avatar
Nope. Front right
edgewant
Old 05-16-2018, 03:32 PM   #4
edgewant's Avatar
Never hit a curb
edgewant
Old 05-16-2018, 05:06 PM   #5
Iwannacamp's Avatar
Be sure and keep the carcass...assuming. I am pretty sure a dealer will adjust that tire for you.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 05-16-2018, 05:25 PM   #6
edgewant's Avatar
Haven’t had luck with that yet. Corporate Michelin is required to look at it. Dealer doesn’t want to adjust.
edgewant
Old 05-16-2018, 05:56 PM   #7
If “they” said it was from impact you must have hit something. Same fault on same tire would suggest to me you hit the same thing twice. Hopefully Michelin can look at it to be sure it wasn’t a defect.
zuckerburg is offline   Reply With Quote
Old 05-16-2018, 07:31 PM   #8
hordok's Avatar
There used to be a tire “expert” that hung out in this forum. I always found his comments interesting and useful.
Wonder if he’s still around?
2016 Charleston BH
hordok is offline   Reply With Quote
Old 05-17-2018, 08:20 AM   #9
edgewant's Avatar
I’m not sure Michelin would admit it if it was a defect. Sales would suffer.
edgewant
Old 05-17-2018, 08:24 AM   #10
Herk7769's Avatar
Underinflation for the load can also cause sidewall separation.
Once that starts happening, the failure is inevitable, but not necessarily immediate.
HAM CALLSIGN - KC3FFW
tire
