Old 02-13-2015, 01:21 PM   #1
Another Newbie looking for advice.
Hi, I'm looking seriously at Berkshire 390BH units. All three are 2014 used, with reasonably low mileage. The biggest question I have is about the engine size. Two of the units have 360hp and one has a 340hp engine. I will be towing a Lincoln MKX probably on a tow dolly, but that is another question in itself. Is there really a big difference between the two engines?
Paulie Boy is offline   Reply With Quote
Old 02-13-2015, 01:44 PM   #2
Berkshire 390QS
NO3putt's Avatar
Between the 340 and 360, 360 is the right one if the prices are close. I believe the 340 can tow 5,000 lbs and 360 is 10,000 lbs. The 340 should have allison 2500 transmission vs the 360 having a 3000 transmission.
I'm sure others will chime in, we have a 340.
Old 02-13-2015, 02:25 PM   #3
JTN8's Avatar
I have the 340 and tow a 4200 pound Cadillac SRX and have no problems at all and never been over weight even full of water! Honestly the biggest difference is the GCVWR!! The 340 is limited to 33,000 only because the transmission not the suspension since the 14's have the beefed up suspension, air bags and tires.
Jason
Old 02-13-2015, 02:25 PM   #4
Campin Cajun's Avatar
I have the 390BH with the 340. NO3putt is correct, if the prices are close I would go with the 360. Although I have no problems towing my JKU. Mine is a 2013. There were other improvements to the 2014's. Look them both over really good and I'm sure you will find the differences.
The 2014 360 has the beefier suspension also.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 02-13-2015, 10:20 PM   #5
Jason
Some of us 2011 have that "beefed up" tires and airbags.
Old 02-14-2015, 08:37 AM   #6
ceedog's Avatar
My 2011 has been 'beefed' up also. The limiting factor in Toad weight is the tow hitch. I've seen Berks with a 10,000lb tow hitch installed. How much does your toad weigh?
According to a FL technician the 340 ISB can be worked to provide 400hp with minimal effort & expense.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 02-14-2015, 08:44 AM   #7
The limiting factor in. 340 HP is the 2500 transmission limiting the GVCW to 33,000 lbs. The hitches are all the same. The 360 has a 3000 transmission and a larger rear axle.
Old 02-14-2015, 08:55 AM   #8
The curb weight of the MKX is 4300#. Just sounds like I would be pushing the limits with the 5000# hitch on the 340hp.
Old 02-14-2015, 09:07 AM   #9
I-RV's Avatar
Welcome to the forum.
The GCWR and GVWR ratings are most important. The Allison 2500MH in the 340 limits the GCWR to 33,000 lbs. (forget the hitch rating)
You need to first figure how much you will load the RV (with occupants), see if that is within the GVWR and then subtract that from the GCWR, which will give you what you can tow. You can get your fully loaded weight by having your motorhome weighed (fully loaded) after purchase, but that is not what you should do. See.............
RV and Vehicle Weight Definitions
With the UVW and CCC ratings, you can do some calculations. Unfortunately, these ratings are not always supplied.
The yellow sticker on the motorhome's front door has information not in the brochures. You should get that info.; it will help you decide. Forget the Hp difference between the 340 and 360, the load carry capability is most important.
Hank
I-RV is offline   Reply With Quote
Old 02-14-2015, 09:50 AM   #10
I would suggest that you weigh any RV before you buy it. The yellow sticker isn't always accurate. Know your empty weight and your traveling down the road weight.
newbie
