WeBoost Cell Phone booster and Antenna
I added a trucker/RV Antenna to my roof, just in front of the kitchen vent (as far as I could go from the front passenger seat). I show this in the first photo.
Note two features:
1. I cut 6 pieces PEX 1/2" pipe (white) and drilled them so that they would fit over the lateral antenna parts and then secured them in place with some cable ties (black). The screw in parts can fall out easily and this prevents them from snagging on foliage as I drive under a tree.
2. I mounted this to a 1/8" (nominal) pipe arrangement with a covering of PEX pipe so that this would allow the antenna to rotate if it snags a tree branch. The pipe arrangement is attached to the roof with a pipe-threaded floor mount. Everything is glued in place with Sikaflex (grey).
The second photo shows how it goes through my roof. I sighted everything off of items that already go through the roof, such as vents and air conditioners. Again, it is sealed with Sikaflex.
The third photo shows the WeBoost mounted on the cabinet above the passenger (the kitchen slide is retracted on the right).
