Originally Posted by BamaBob
Gordon,
Have you seen where WeBoost has JUST released a booster setup specifically for RVs? [ https://store.weboost.com/products/drive-4g-x-rv]
If you have the 4GX already, it is just a antenna swap out (inside & outside) - and the new outside antenna does NOT need a metal base plate
You can also upgrade your indoor antenna to a wall mount instead of the desktop one included with the new unit.
Bob,
That's a new one for me. Thanks for the heads up.
But, I prefer the setup that I have. I can't see what RV antenna that they provide with the standard 4GX Drive kit, with the extra outside antenna. Mine is pretty sophisticated. It has a base loading coil and two sets of 3 lateral antenna parts (I forget the name), that define a horizontal plane. So, the outdoor antenna is probably the best I can get. Just had to work to mount it properly, so I dreamed up the pipe system.
The standard indoor antenna for the 4GX is better for me than an omnidirectional antenna that is mounted in place. Mine comes on a long wire (about 6 feet or so), that I can put anywhere in the driver area, the sofa or the kitchen table. When the signals are weak, I put it right next to my phone or iPad. This allows the phone or iPad to communicate with the indoor antenna using a minimal power level. The minimal power level reduces the risk of feedback with the outdoor antenna when it is searching for a weak signal.
I don't always see a gain with this system, but it is noticeable when the signal is very weak.
I can take the 4GX off the wall and put it in my toad for when we drive around.
–Gordon
