Old 07-02-2016, 07:22 PM   #1
Chessie's Avatar
Any advice on getting a good tire gauge that will reach the inside rear tires stems?
Hello folks,
I am picking up our new 2017 Berkshire XL 40 on the 13th and I want to be ready for my (solo) 2200 miles trip home from Grand Rapids Michigan to Southern California. I don't trust the dealer to have set the proper tire pressure for the correct weight (the MH will basically be empty except for fluids) and me, so I will probably set the pressure at either 100-90 or 105-95 until I find a scale to verify the weight. Interestingly enough, CAT scales won't do individual wheel weighting claiming it might damage the MH, so I will measure axle weight and use the Michelin chart to figure out the right pressure.
Am I on the right track?
I also would like to purchase an accurate gauge that will reach the inside tires valve stem. What are your folks using?
I am new to RV, so I definitively appreciate any feedback and advice your folks can provide.
I love this forum, it is an amazing source of information thank you everyone for all your support this far. You all have been great.
PS. If you see Bershire XL in English Burgundy livery (white and black front with red, white and grey sides) driving on i96, or i80, or i70 going west, give a wave and a toot....if I am parked on the side of the road with flashers on, please help...
Cheers,
Elisabeth, Jacques and 6 year old Gabriel
Maggie (9 year old Otterhound) and Bodhi (19 months Golden Doodle)
2017 Berkshire XL40BH-380
Chessie is offline   Reply With Quote
Old 07-02-2016, 08:31 PM   #2
You are on the right track. There is a cat scale less that a mile from Moho2go. 131 and 76 street. It's called 76 street truck stop. Are you staying in the area for a few days? I strongly suggest staying for a few days. Checking all the systems out to make sure it's all working before you get to far.
Old 07-02-2016, 09:06 PM   #3
Chessie's Avatar
Thanks Phil, unfortunately I am on tight schedule, I need to be home Sunday evening...., I am however planning to spend as much time as I need at the dealership to fully understand and operate all the systems before I go.
Whatever issues surface while on the road will have to be addressed by the local dealer in SoCal if they are not issues that live me stranded.
I have spend 40 years around boats as a professional captain and like Mh's boats breakdown a lot, so I don't have unrealistic expectations....
Thank you for the tip for the CAT scales, I will definitely stop there on my way.
Old 07-02-2016, 10:26 PM   #4
Mmnsc's Avatar
Hi
Congratulations on your new motor home. I hope you have a flawless trip back to CA.
I purchased a digital tire pressure gauge from Tire Minder ( Company is Minder Research in Florida). It comes with 2extension tips and works well on my Berkshire.
Marty
Mmnsc is offline   Reply With Quote
Old 07-03-2016, 06:30 AM   #5
Just going through the Camp Freightliner class Mike Cody the facilitator highly recommended the "Milton 976" tire pressure gauge. Guaranteed to be accurate to 2%. Under $20.00 on Amazon.
Bunci is offline   Reply With Quote
Old 07-03-2016, 08:09 AM   #6
I-RV's Avatar
Jacques - Your rear wheels should already have air line extensions. You are on the right track for your concern about tire pressure and weight. I suggest that you set your pressure in accordance to the weight/pressure chart for your particular model/size tires, from the manufacturers specifications.
I have heard that some of the cheapo digital gauges are more accurate then expensive analog types. This is because the digital manufacture can more easily insert corrections into the gauge. You might also consider a TPMS (Tire Pressure Monitoring System) at some point.
Don't be surprised if your local FR dealer in CA is reluctant to do warranty work. Good luck and many happy miles and experiences with your new motorhome.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 07-03-2016, 09:16 AM   #7
Hank
If the local dealer has issues with where you bought the rig one quick call to Diesel Division should bring them around quickly.
Old 07-03-2016, 09:23 AM   #8
Chessie's Avatar
Now I am worried about getting warranty work done at the local dealer. I assumed that RV dealers worked like automotive dealers and performed warranty work regardless of where the vehicle was purchased. It looks like by the posts I received that I was wrong.
I will call FR diesel division on Tuesday and found out what their position is, I might call the service department of local dealer as well and introduce myself and see how well that goes.
Old 07-03-2016, 09:49 AM   #9
W5CI's Avatar
do a Extra through PDI insp and have all discrepancies fixed before you sign and pay for the rig, Once you sign and pay it is yours. Take plenty of time and spend a couple of days in the unit before leaving for home, once again when you leave it is yours. good luck with your new MH
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 07-03-2016, 10:00 AM   #10
RKNOLA's Avatar
Hi Jacques,
Good Luck on your PDI! Have a pad of paper and a roll of blue painter's tape ready. Any issues you find or want to ask about put a small piece of the blue tape on it and note it on your pad. That way it doesn't get forgotten during the very LONG and very overwhelming PDI. Also remember to bring a DVD with you so you can check the DVD player.
We are all here and willing to help at any time.
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
tire, tires
