Old 04-20-2015, 12:16 PM   #1
Fulltime in our Berkshire
KennyGolub's Avatar
Any Berk owners that are Ham Radio Ops ?
I know there are a few threads around about antenna installs on coaches, 5ers and TTs, but I was just curious if any Berk owners have successfully mounted mobile hf antennas on their Berk.
I was thinking possibly using the 9/16ths bolt at the top of the mirror arm.
Thanks,
Ken
KennyGolub is offline   Reply With Quote
Old 04-29-2015, 12:59 PM   #2
john1345's Avatar
I have, all my cables run un the coach and up the ladder. HF antenna and erection fixture is mounded to the ladder. I'm thinking about selling the fixture and mount it on the roof I have a Tarheel lift and lay unit I will put on the roof. I use a Hi Q 10 thru 160 antenna with a Henry SS-750 amp. Contact me off line for more info W7JL@W7JL.net
john1345 is offline   Reply With Quote
Old 04-29-2015, 02:54 PM   #3
the 9/16 on the mirror arm is for releasing the mirror and for it's adjustment!!
You can connect the antenna to the mirror arm with drill screws .
drill a hole at the bottom of the arm and run the cables into the cabin.
the mirror element is hollow ,all the electrical wires that operate the mirror are there!
The simplest way is to take off the whole mirror element, (two screws that connect the body) look out !! there is rubber insulation layer , save it !!
There is a hole in the body you can pass through it without a problem antenna cables.
i did it
Hashimshony is offline   Reply With Quote
Old 04-29-2015, 04:47 PM   #4
KennyGolub's Avatar
Wow.....any chance you have photos?
I want to attach my tarheel (the smaller one) screw driver antenna.
Thanks,
Ken
i did it
Old 04-29-2015, 05:40 PM   #5
Hi,
Here is one, not so good
Sorry , it's in a storage and I am thousands miles away
radio
