Old 03-16-2014, 06:38 PM   #31
I-RV's Avatar
Originally Posted by ernest917 View Post
After reading all the posts, I decided to just go back with a regular Suburban 10 gal like I had.....
That sounds good to me, but where would you install it.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 03-16-2014, 07:46 PM   #32
ernest917's Avatar
Tankless heater slides right into existing water heater opening.....
ernest917 is offline   Reply With Quote
Old 03-17-2014, 08:48 AM   #33
I-RV's Avatar
You said that you would like to go back to the Surburban 10 gal. I do not think that it will go into where a tankless was. Yes a tankless will go where a Surburban was. Therefore I do no understand your last reply.
Old 03-17-2014, 10:52 AM   #34
ernest917's Avatar
You misunderstood - I had a suburban and considered going tankless but decided against it....
Old 03-17-2014, 12:55 PM   #35
Cyclone
beipers's Avatar
In my Berk with the water heater on the right rear, there is plenty of room for a 10 gallon water heater. With the new configuration for 2014, I'm not sure.
Sent from my SCH-R530U using Forest River Forums mobile app
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 03-17-2014, 01:56 PM   #36
In my 2011 it would take major fabrication to get a ten gal in. If you have a tank type now I can see staying with the same system. If it's a tankless I would push to have FR or Gerrard make it right. I started with a gen 1 and got it to work ok but not great. With the gen 2 there is no way I would go to a tank type system. I can take a ten minute shower if I want and never run out of HW. I would let FR and Gerrard have the chance to make it right. I do believe they will.
Old 03-17-2014, 03:12 PM   #37
Cyclone
beipers's Avatar
Phil
I truly believe they would too.
2015 SOB 5th Wheel
Old 03-17-2014, 05:52 PM   #38
ernest917's Avatar
I just put a Suburban SW10DE (10 gal ) water heater in my 2008 Berk with no mod required.... I'm sitting in my rig at the FMCA Perry rally and it's pumping out hot water......
Old 03-17-2014, 05:57 PM   #39
tmmar's Avatar
Ernest,
Didn't the '08 have a Suburban 10 gal in it originally? I know mine did.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-17-2014, 06:08 PM   #40
ernest917's Avatar
Yes it did therefore no mod needed.... The Gerrard tankless unit slides right into the existing opening but as I stated earlier, I opted out of the tankless....
heater, tank, water, water heater
