Old 02-17-2014, 10:02 PM   #1
tmmar's Avatar
Any tips on the tankless water heater
Has anyone mastered the Garrard tankless water heater? After 3 weeks of using the water heater, I still have not been able to take a shower without the water getting cool. Have plenty of water pressure (about 40psi) and I make sure that there is no air in the system. Not sure what else to try. Any tips?
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 02-17-2014, 10:33 PM   #2
Campin Cajun's Avatar
I set my thermostat about halfway. I run just hot water for a few minutes then move the shower faucet about to the half way position the temp does change a little but I wouldn't call it cool to hot, more like hot to warm..
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 02-18-2014, 04:35 AM   #3
I do the same. I also use a Oxygenics Body Spa Handheld Shower Kit, White
Oxygenics (69). That seams to help also. I change the thermostats with the outside temp a little at a time. Always full blast and about in the middle between hot and cold.
Old 02-18-2014, 04:48 AM   #4
Having one in the house prepared me for the RV. It is the flow regulator in the shower head. May not be the best for water conservation when you are running off the tank alone, but I would be surprised if you removed the regulator or swapped it out and the problem didn't fix itself.
JJvike is offline   Reply With Quote
Old 02-18-2014, 07:25 AM   #5
TURBS's Avatar
Lol no offense but im done taking a shower "in a few minutes"
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-18-2014, 02:21 PM   #6
I mean is I let the water heat up with just hot water running. I take long showers lol
Old 02-18-2014, 02:34 PM   #7
jevanb's Avatar
it has a low/high switch , put to low for showers, and turn the hot water knob only... in some areas where the ground water is warm , like above 60 degrees their is a mod to fix this issue, I had lots of issues with mine last year and spent a bunch of time on the phone with the techs at girard, finally got it to work right, and it is nice..
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-18-2014, 03:26 PM   #8
Iggy's Avatar
Questions....
Have you ever gotten a lot of hot water out of it ever?
Is the bypass valve open?
2012 Georgetown XL - 378TS 60K + miles
Old 02-18-2014, 05:34 PM   #9
tmmar's Avatar
I run the water and I get very hot water from my shower head (Oxygenics) and after the water is flowing very hot, I adjust it to a comfortable temperature. While showering the temp varies from hot to tepid. Not sure why the temps vary and that is my problem.
Tom and Margaret
Old 02-18-2014, 08:49 PM   #10
Cyclone
beipers's Avatar
I've learned that the shower control always allows some cold water through. I shut the cold water to the shower off at the outside manifold in all but the warmest weather in the summer. We then use the auto (which is wired as high) / low switch to keep the kids from burning themselves.
After reading most of the threads on the forums, I've already decided, when ours dies, I'm going back to one with a tank. I can make the shower work, but I hate living with the cold blast while trying to wash the dishes. In my opinion, it wastes too much water when dry camping waiting to get the long line from the heater to the shower / sink warm when starting either.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
heater, tank, water, water heater
