Old 06-02-2012, 12:23 PM   #11
FreedomTracker's Avatar
Amazon SS Camco grill looks good. How much better do you think the quality is over the original black grill that came with the TT.?
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-02-2012, 12:24 PM   #12
tmmar's Avatar
Originally Posted by TaterColo View Post
Here is the link to the grill I purchased from Amazon. The grill came with the quick connect built into the grill. It also came with 1 hose (about 3 feet long). I purchased another hose (not knowing it came with one), however I can hook those 2 hoses together and get close to 12 feet of length.
Does your grill have a regulator? If so I don't believe you can use that as the MH is regulated at the connector.
I also have a Weber Q and removed the regulator and put on a quick connect for the supply hose. I was able to get one made up at a local camping store. He made it on the spot and made it to any length that I wanted.
While your idea of attaching the grill to the door is nice, I personally want my grill as far away from the coach as possible when I am using it. I feel that the chance of the grill flaming up while grilling burgers, steak, or anything else will probably occur and I don't want those flames and heat anywhere near the fiberglass sides. JMHO.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-02-2012, 12:28 PM   #13
2011 Berkshire 390BH-60
TaterColo's Avatar
Originally Posted by mjracsj View Post
My Weber Q220 does have a regulator. I tested it and it works but that may explain why the gas pressure seemed low and it took a long time to heat up.
You are exactly right.
TaterColo is offline   Reply With Quote
Old 06-02-2012, 12:32 PM   #14
TaterColo's Avatar
Used it over memorial for grilling burgers and chicken. It flamed up a bit but I was was not concerned about the fiberglass. I feel it sits far enough away from the sides the flames will not get close enough to damage the sides of the RV.
