Originally Posted by TaterColo
Here is the link to the grill I purchased from Amazon. The grill came with the quick connect built into the grill. It also came with 1 hose (about 3 feet long). I purchased another hose (not knowing it came with one), however I can hook those 2 hoses together and get close to 12 feet of length.
Does your grill have a regulator? If so I don't believe you can use that as the MH is regulated at the connector.
I also have a Weber Q and removed the regulator and put on a quick connect for the supply hose. I was able to get one made up at a local camping store. He made it on the spot and made it to any length that I wanted.
While your idea of attaching the grill to the door is nice, I personally want my grill as far away from the coach as possible when I am using it. I feel that the chance of the grill flaming up while grilling burgers, steak, or anything else will probably occur and I don't want those flames and heat anywhere near the fiberglass sides. JMHO.
