Old 05-17-2012, 10:40 AM   #1
2011 Berkshire 390BH-60
TaterColo's Avatar
Attached my grill
I need to move the bracket to the bay door beneath the water heater. My wife pointed out I'd have to BBQ under the slide - oops. I just told her to put the slide in. It feels very sturdy.
TaterColo is offline   Reply With Quote
Old 05-23-2012, 10:58 AM   #2
That is a nice looking do you leave it attached when you travel or do you take the grill off the door? what type of grill and bracket is it?
csichoice is offline   Reply With Quote
Old 05-23-2012, 12:32 PM   #3
TaterColo's Avatar
The bracket I ordered along with the grill from Amazon. Cheapest place I could find the grill. It's an Olympian 5500. I also ordered the carry case as well.
Old 06-01-2012, 08:12 PM   #4
How did you attach the propane, we can't seem to find the 1/2 inch fitting.
macdonaldatl is offline   Reply With Quote
Old 06-01-2012, 08:46 PM   #5
TaterColo's Avatar
On the passenger side of the coach in the bay door below the fridge (the only bay door that opens outwards with no slide above it ) look inside to you left. You will see the fitting there.
Old 06-02-2012, 07:24 AM   #6
Thank you, found the fitting, but it does not fit the portable grill, we have a Weber, but they all seem to be standard 1/8in. Did you have to modify the quick connections? We have a new 2011 390bh, seems strange that it would be so hard to attach a portable grill.
Old 06-02-2012, 07:31 AM   #7
Ok my mistake, it is the 2012 model, and the Weber has a 1/4 in female, and the MH has a 1129f, male 1/2 in. We can't seem to find a propane conection wire.
Old 06-02-2012, 08:59 AM   #8
mjracsj's Avatar
We have a Weber Grill we use for our 2011 Berkshire. Any rv dealer should have a hose with the proper quick connect to connect to the motorhomes fitting but shey all seem to only have short hoses. I then took that hose to a propane service company who made an extension for it as I wanted the Grill farther away from the coach out on a picnic table. I had tried a propane company first but there are many different quick connect fittings and rv dealers seemed the only place that had the right one.
mjracsj is offline   Reply With Quote
Old 06-02-2012, 11:52 AM   #9
TaterColo's Avatar
Here is the link to the grill I purchased from Amazon. The grill came with the quick connect built into the grill. It also came with 1 hose (about 3 feet long). I purchased another hose (not knowing it came with one), however I can hook those 2 hoses together and get close to 12 feet of length.
Does your grill have a regulator? If so I don't believe you can use that as the MH is regulated at the connector.
Amazon.com: Camco 57305 Olympian 5500 Stainless Steel Grill: Automotive
The additional hose
Amazon.com: Camco 57280 39" RV Quick-Connect to Quick-Connect LP Gas Hose: Automotive
...and the storage bag
Amazon.com: Camco 57632 Olympian Grill Storage Bag: Automotive
Old 06-02-2012, 12:21 PM   #10
mjracsj's Avatar
My Weber Q220 does have a regulator. I tested it and it works but that may explain why the gas pressure seemed low and it took a long time to heat up.
Old 06-02-2012, 12:23 PM   #11
FreedomTracker's Avatar
Amazon SS Camco grill looks good. How much better do you think the quality is over the original black grill that came with the TT.?
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-02-2012, 12:24 PM   #12
tmmar's Avatar
I also have a Weber Q and removed the regulator and put on a quick connect for the supply hose. I was able to get one made up at a local camping store. He made it on the spot and made it to any length that I wanted.
While your idea of attaching the grill to the door is nice, I personally want my grill as far away from the coach as possible when I am using it. I feel that the chance of the grill flaming up while grilling burgers, steak, or anything else will probably occur and I don't want those flames and heat anywhere near the fiberglass sides. JMHO.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-02-2012, 12:28 PM   #13
TaterColo's Avatar
You are exactly right.
Old 06-02-2012, 12:32 PM   #14
TaterColo's Avatar
Used it over memorial for grilling burgers and chicken. It flamed up a bit but I was was not concerned about the fiberglass. I feel it sits far enough away from the sides the flames will not get close enough to damage the sides of the RV.
