Old 08-07-2016, 06:40 AM   #1
Atwood on demand water heater
Looking for some suggestions:
2017 Berk 38A: Atwood on demand water heater:
the heater has worked several times, now out on another trip and no hot water.
1. Not using any water regulator so there is plenty of flow.
2. Have checked both fuses they are good.
3. Power vent runs when hot water is turned on.
4. Do not see any spark or any flame.
5. There is a full tank of gas (stove works and tank is 3/4 full)
Does anyone have any other suggestions??
Thanks Joe
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2016 Ford Edge
2016: days camped 60
2017: days camped 26
joet19711 is offline   Reply With Quote
Old 08-07-2016, 07:36 AM   #2
When you take the cover off outside, there is a reset button on top left corner that kept blowing on mine. Took it in and found out there was a recall on a part that got replaced. Has been working ever since. Thats on a 2016 Sandstorm. ??
guyster is offline   Reply With Quote
Old 08-07-2016, 08:17 AM   #3
I have already checked, it is the ECO (high temp switch) and I have a closed circuit there..
thanks for the input...I wish I had my old electric hot water heater back(from my other coach)
Joe & Kathy
Old 08-07-2016, 08:27 AM   #4
15berkxl's Avatar
Thanks Joe
Number one problem is black vent tube gets plugged remove it carefully and make sure nothing is in it. Also take tooth pick or pipe cleaner and clean out tube connection at pressure switch.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 08-07-2016, 09:01 AM   #5
Wayne
Wayne I can not thank you enough...
took off black tube, it was clear...but where tube came from was full of dirt.
took tooth pick and cleaned out and heater is working now.
I owe you big time, and hope we run into you somewhere.
we are from Delaware and West Virginia and could be at either place..
get in touch if you are near either place..
thanks again
k t
Joe & Kathy
Old 08-07-2016, 09:19 AM   #6
15berkxl's Avatar
No problem glad to help learned from experience on that one. Just pay forward and help others.
Wayne
Wayne
Old 08-07-2016, 09:25 AM   #7
Wayne
You can count on me to do just that..
thanks again
Joe & Kathy
Old 08-07-2016, 10:55 AM   #8
thanks again
A suggestion is to reposition the black tube so it faces in side the compartment. Then block the hole that it used to go through with tape or something from the inside. This will keep you from having a repeat of the issue. I fixed mine several times and had to replace the pressure switch. Mud Daubers were the culprit. I did talk to Atwood CS and that is the fix they also recommend. The also admitted to a poor design on that tube.
Old 08-07-2016, 03:21 PM   #9
Sounds good Phil, going to go and do that now.
What does the black tube do??? Does it just equalize the pressure on the Pressure Switch??
Joe & Kathy
Old 08-07-2016, 03:39 PM   #10
I believe it does but I don't know. A good way to test the pressure switch is to turn on hot water and touch the two brown wires together. Is the burner fires you have a pressure switch issues and most likely in the black tube.
heater, water, water heater
