Old 06-06-2015, 06:05 PM   #1
ndfellow's Avatar
Auto level
Couple questions here, 1: if I turn on the auto level, hit auto level and the coach does it thing, how do I reset what it believes to be level because after its finished I still have to manually level the unit. 2. After a day or each day I have to keep leveling the coach and cannot hit auto level gain u til I retract all then auto level works again? Last is there a "spot" wherein should put a level to see what the coach thinks is level vs the middle of the floor?
I will say I'm able to get it level myself but auto level is never right
ndfellow is offline   Reply With Quote
Old 06-06-2015, 06:31 PM   #2
We had the same problem with both our Georgetown and Forester -- need to have it re-calibrated.
SkipnTerri is offline   Reply With Quote
Old 06-06-2015, 06:34 PM   #3
ndfellow's Avatar
Where? Dealership?
Old 06-06-2015, 06:34 PM   #4
bubbles's Avatar
If it's an LCI (Lippert) system the program procedure for auto level is in your manual. Here's the procedure:
LEVEL ZERO POINT CALIBRATION
Before auto-leveling features are available, the Level Zero point must be set. This is the point to which the system will return when an auto leveling cycle is initiated. To set the zero point (controller module must be fully secured in production intent location), first run a manual leveling sequence to get the vehicle to the desired level point. Then activate the Level Zero point configuration mode.
This mode is enabled by performing the following sequence:
1. Turn panel off. Then turn panel on.
2. Perform the following: -Press the FRONT switch 5 times. -Press the REAR switch 5 times.
3. At this point all LED outputs will blink, and the buzzer will be off.
4. You are now in IDLE mode ready to set Zero Point.
5. Press the RETRACT ALL switch 3 times to set the Zero Point.
Old 06-06-2015, 06:36 PM   #5
JTN8's Avatar
You can easily set the null point yourself. There are procedures in the manual or you can google them. I usually reset mine once a year. If you have to keep leveling the coach after a day or two, I'd say you have a hydraulic leak or something is wrong with one of your jacks
Jason
2014 Berkshire 390BH
2011 cadillac SRX
Old 06-06-2015, 06:36 PM   #6
Where? Dealership?
We had Camping World do it, but Owner's Manual does explain how to 0-level
Old 06-06-2015, 06:46 PM   #7
bubbles's Avatar
One other point. There should be no movement of anyone in the coach while the leveler is in auto level operation.
Old 06-06-2015, 07:07 PM   #8
Berkshire 390QS
NO3putt's Avatar
It is easy to do, no need to visit RV dealer toset null (level) point.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 06-06-2015, 09:56 PM   #9
ndfellow's Avatar
Guys I'm confused here when I turn the panel on and hit the front button 5 times it u levels the coach by going up or down?
Old 06-07-2015, 06:56 AM   #10
bubbles's Avatar
The quote you cited refers to auto levelling your coach when using auto level not part of calibration procedure. If your system is the Lippert hydraulic system the calibration will work. You only turn the system on but do not select man or auto to do the calibration. Follow the procedure as written, don't read something into it that isn't there. If you have strut movement when you hit the leveler buttons 5 times there's something wrong with your system. If your system is not the Lippert hydraulic system this procedure is moot for you.
Old 06-07-2015, 07:29 AM   #11
tmmar's Avatar
nd,
your coach has an equalizer leveling system. Look on their website or in your manual for instructions on how to set your auto level. I usually put a small round level in a few spots in the middle of the coach on the floor just to make sure that the tile itself is level.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-07-2015, 07:41 AM   #12
bubbles's Avatar
If you have the equalizer system this may help:
Setting the Null: The Null or “Level Position” has been preset from the Factory. However, if the coach is not level following an attempt to AUTOLEVEL, the Null is easy to reprogram. To set the Null, Apply Park Brake, Turn the Ignition Key On, push and release the Keypad POWER Button to engage power. The POWER Button and Ignition On (LED’s), should be lit RED when power is on. Level the coach by deploying jacks manually (using the DOWN ▼ keypad buttons, extend each jack until the coach is level), or by simply parking the coach on a Level Site. You do not need to have jacks deployed to set the Null. Use a bubble level on a flat surface in the center of the coach as a reference. Once the coach is leveled, turn the Ignition Key Off and the Panel can now be turned Off. Now Depress and hold the AUTOLEVEL Button, Continue to hold the AUTO-LEVEL Button and then press and release the POWER button, Listen for a Series of Beeps. After the panel has beeped 5 to 6 seconds, release the AUTO-LEVEL button (the keypad will continue to beep as long as the AUTO-LEVEL Button is held). The New Null Setting has been set and the panel will maintain this setting. Press and release the ALL RETRACT Button to retract the jacks to the Stowed/Travel position.
