Old 05-21-2012, 10:05 PM   #1
Auto Leveler won't auto level
went to park motorhome, and turned off engine and pressed power button on auto level and it does nothing!!!! I swear I am jinxed!!! It has always worked before so I don't know what could have happened in 2 hr drive home.
mx800 is offline   Reply With Quote
Old 05-21-2012, 10:18 PM   #2
All of these fancy gizmos they are adding to RVs is kindof like computers. Its all great until the thing quits working!
Your problem sounds like a simple lack of power, but the trick will be to track down the cause. Maybe just start checking for power at the switch, and follow the path until the power quits?
Wish I could be more help.
DonG is offline   Reply With Quote
Old 05-21-2012, 11:07 PM   #3
TURBS's Avatar
did the air ride bleed out when you hit auto level ?
Old 05-22-2012, 10:33 AM   #4
ronhanson's Avatar
Parking brake on?
If you have Lippert jacks, they say to leave the motor running while leveling.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 05-22-2012, 03:59 PM   #5
Not a expert but when we had our orientation they pulled the keys out before hitting the auto level button. I think he said it won't work with the key on. I haven't picked it up yet so I could be wrong.
Old 05-23-2012, 02:56 PM   #6
Anacortesians
We have auto-level, but it lifts the rig so high, it feels like it will topple over. Ours works with two jacks at a time - front two, back two, left two or right two.
My technique is to run the front and back pairs down until a jack touches. Then I go outside and see what needs doing next to get all four touching the ground.
Once that's achieved, I then go for the minimal amout of extra extension that will get me level. I have two stick-on levels close to the driver's seat which I installed after getting the rig level on my driveway using a torpedo level in the bottom of the fridge.
If it takes a lot to get level, I'm not shy about asking for another site, or even going elsewhere.
Frank and Eileen
No longer RVers or FR owners
Old 05-23-2012, 05:55 PM   #7
Went out and tried it again, and VOILA it works now. No idea what I did, but it levelled out fine.
Thanks for all the help
Old 05-23-2012, 11:01 PM   #8
2011 Berkshire 390BH-60
TaterColo's Avatar
It automagically fixed itself! That's the cheapest way to go.
TaterColo is offline   Reply With Quote
