Old 06-23-2015, 09:12 AM   #1
Automatic awning
My awning won't retract. Does anyone know if it can be retracted manually,if so how? Or better yet would anyone know what might be wrong with it? Thanks Jim.
jrlebaron is offline   Reply With Quote
Old 06-23-2015, 09:23 AM   #2
Can run from (Fuse/switch/Motor/or just Stuck) Since it is a 2008 age plays into it also,but Brand NEW ones fail also! Youroo!!
Old 06-23-2015, 09:32 AM   #3
mark0224's Avatar
I would ck all fuses and switch first and make sure you have power all the way o the motor. If all else fails this is how mine can manually retract, but after you do this you need to take it in for service. http://www.primetimerv.com/download/...-UserGuide.pdf
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
awning
