Old 08-27-2014, 10:45 PM   #31
Originally Posted by Mbh818 View Post
Excellent reference to the rvnetwork thread, Boo. Thank you.
You are more than welcome, Mike. I thought so too.
Boowho??
boowho is offline   Reply With Quote
Old 09-15-2014, 04:37 PM   #32
RKC02's Avatar
Does anyone use or have explored the SMI Delta Force portable brake?
It compares favorably with the RVi2 brake (very close in price as well) but also offers dual-signal activation and it is anchored by a tether cable rather than pushing on the seat or seat pan. Seems like a good system.
Just wondering if there is any real-life experience with this unit.
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 09-15-2014, 10:01 PM   #33
I-RV's Avatar
I feel that the SMI Air Force One is a great toad brake. It uses the air from the RV's brakes and thus applies the toad's brakes in proportion to the RV's. There is no setup to put anything in the toad when it is time to tow. It has a reserve air tank in the toad for break-away situations. I'd like to hear from anyone that has used it.
Hank
2012 Berkshire 390BH
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-16-2014, 07:38 PM   #34
RKC02's Avatar
I-RV: I feel the same about the AF1 but was advised against it by Freightliner. They recommended US Gear Unified Brake but I found out that company lost the patent on a key component and cannot sell it as a complete set now (questionable future?). I really like the Stay in Play Duo as an alternative to AF1 though.
Same basic components as AF1 with dual signal activation. Only thing lacking is a dash unit for the coach but a notification light can be added.
RKC02
Old 09-19-2014, 07:30 AM   #35
I-RV's Avatar
H'mm, dose not appear that anyone within shouting distance of this forum has used AF1. I guess that says something!
Hank
Old 09-19-2014, 09:21 AM   #36
RKC02's Avatar
I decided to keep it simple and purchased SMI's Delta Force portable braking unit. It has the capability for dual-signal activation using inertia (which all the other 'boxes' use alone), plus the brake light signal from the coach. Seems like a good unit so I took the plunge. Since it just came out this summer I have not been able to find any reviews. I am awaiting delivery of the unit then installation of the baseplate and wiring of our new car on the 29th, but I will post a full review once I get to use it on the 30th.
*The choice of the Delta Force over the RVi2 unit was based on physical size of the units. Our new Ford Flex has an oddly contoured floor pan which would have had the RVi2 unit sitting at a downward angle and also required installation of a stop pan to hold the unit in place. The Delta Force has a smaller footprint and is tethered to the firewall by a cable to not only keep it in place but eliminate the need to brace the unit against the seat.
Old 09-19-2014, 09:59 AM   #37
kenandterry's Avatar
Remind me to never deal with the trailer place RKC02 mentioned for advice!!!!!!
His kind of help or opinion is of no use to anyone
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 09-20-2014, 12:34 AM   #38
edgewant's Avatar
I have the AF1 system and love it. I did the install myself and the hardest part was getting the courage to cut the chassis air line. The fact that the system has a check valve to prevent failure of the chassis brakes in the event of a leak eased my mind though. I have not read the literature in about 8 months so I may be wrong but I thought I recalled it being approved by Freightliner.
Initially I had difficulty seeing the brake notification lights that mount to the toad rearview mirror and face fowards and are intended to be visible in the rearview camera. Once I adjusted my camera contrast it was easier.
I towed for almost a year without an aux braking system but attended an FMCA rally in Perry GA this past March and the liability issue in the event of an accident put the fear in me. I can tell a difference when hard braking is required.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 09-20-2014, 07:40 AM   #39
I-RV's Avatar
Thank you Edgewant; at last I found someone using it on a Brkshire.
Hank
Old 09-20-2014, 11:23 AM   #40
Hank
I had the Air Force 1 installed as soon as we purchased our toad, in July of this year. No fuss, No muss. Just connect the air hose and drive away. Very clean install and it works as advertised.
I do recall my installer asking about which chassis we had and remember him saying Freightliner's air system provided for an easier install than others. We only have about 5000 miles towing but so far I'm pleased.
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
seeg is offline   Reply With Quote
toad
