Old 08-20-2014, 06:07 PM   #1
Average height of our coaches???
Just curious, has anyone measured an exact height of their Berkshire aired up? Looking into garages...
CT Camper is offline   Reply With Quote
Old 08-20-2014, 06:20 PM   #2
I have a 12'6" door on the storage unit I rent for my motorhome. I can fit my 2012 390RB in if I let the air out of my air bags. I am looking for a storage unit with a 14 foot door.
Dave1960 is offline   Reply With Quote
Old 08-20-2014, 06:27 PM   #3
Wow, over 12'6. Seems like the brochure had at 12'4".
Old 08-20-2014, 08:24 PM   #4
Cyclone
beipers's Avatar
The tallest piece on mine is the mini satellite dome (which is an add on over what the brochure would include). I measured it at 12' 7". I always use 12' 9" when figuring door or overpass requirements.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 08-20-2014, 11:10 PM   #5
Same here.... I usually figure on 13 exactly, even though not quite that high. 12 7 to the top of my Winegard is about what I remember last time I measured.
I like the extra 5 inches of cushion. If the sign says less than 13 feet, I start to get concerned.
Boowho??
boowho is offline   Reply With Quote
Old 08-21-2014, 10:21 AM   #6
Word of warning ... that measurement can change dramatically if the unit is on an incline ... especially if passing along a dip while going thru an overpass.
I have on the occasions seen semi units hit the same rail bridge while passing under.
We also need to take into account the height of any vent covers that we put on. I Know that all of mine stick up above the account units.
Cheers
lefaivre is offline   Reply With Quote
Old 08-21-2014, 10:24 AM   #7
Mmnsc's Avatar
We measured ours on a completely flat surface with the air bags inflated. It took 2 people. We took a straught 8 foot aluminum bar and placed it on the highest point which was our rear a/c. We put a 4 foot level on the bar and measures from the bottom of the bar to the ground. It was exactly 13 feet 8 inches. We placed a printed tape above the radio with the measured clearance and also have the measurement in metric 3.89 meters as we occasionally go into Canada. We will not try anything less than 13' 5" as sometimes roads are repaved and they don't remeasure and change the signs
Marty
Mmnsc is online now   Reply With Quote
Old 08-21-2014, 10:25 AM   #8
Mmnsc's Avatar
Correction. The actual measurement was 12 feet 8 inches
Old 08-21-2014, 12:32 PM   #9
Campin Cajun's Avatar
Man you had me worried when you said 13'8"........lol
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-21-2014, 02:27 PM   #10
BamaBob's Avatar
With our aftermarket covers on the fantastic fans, we top out at 12'8" but to be safe, I always call it 13'
BTW, AllStays has a GREAT RV app (Camp & RV) for the iPhone/Pad (Android as well I think) that lists all sorts of neat info INCLUDING routes that have low bridges - and you can filter out how low can you go
Finally, on the way back from Goshen, right after passing under a 14' underpass we spied a oncoming RV with the antenna still in the "upright and fully locked position"
No manner of light flashing and pointing got their attention
Observation 1: A raised TV antenna increases clearance substantially
Observation 2: Watching a RV go under a 14' underpass under "full sail" is the classic defination of Schadenfreude
Observation 3: A $300 Winegard HD antenna when violently seperated from a RV roof leaves a lot of road debris (thankfully no one was following closely)
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 08-21-2014, 02:56 PM   #11
phat phrog stunt crew
had me worried too. even semis without a permit are allowed only 13'6". 13'8" must make your trips very expensive not to mention the route planning involved
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 08-21-2014, 07:03 PM   #12
I had previously measured mine to the top of my Wineguard dome at 12'9", so it sounds like we are all pretty acurate +/- and inch
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
