Originally Posted by JJvike
You can adjust the awning. Our dealer showed us how to do it. Do one side and then the other. When it extends, it will clear the slide. Once extended, the awning will rest on the slide depending on how low you adjust it. I plan on clicking down one adjustment and seeing how it works out. I can't wait to see the rain dump work. I've got a couple friends that could use a shower.
JJ
Not sure why, but my RV tech suggested that I not try to change it. I would like more pitch in the awning, but since there is a slide directly under the awning, may be I shouldn't fool with it.
Either way, it seems like that mechanism could bite pretty hard if you pop out the pin without someone else supporting the awning. A two person job in other words.
I don't like it being so high; makes less shade at certain sun angles.
On my list of things to check on......
Boowho??
