Old 07-30-2016, 10:51 AM   #1
DJP6371's Avatar
Awning adjustment for rain
I have a 390QS and would like to know if there's any way to adjust one side of the awning down to drain water run off in the rain.
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 07-30-2016, 10:58 AM   #2
AquaMan's Avatar
A set of awning poles from Turbs or if you have the adjustment knobs on the arms, just pull the awning down and lock it in place.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-30-2016, 11:02 AM   #3
dan-nickie's Avatar
There is an adjustment on the arms of the Carefree awning for the Berkshire. Mine was running off the front a couple weeks ago and I justed the arm so it run off the backside. I will attach a couple of pictures to show you.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 07-30-2016, 11:03 AM   #4
dan-nickie's Avatar
Front.
Dan
Old 07-30-2016, 11:04 AM   #5
dan-nickie's Avatar
Rear.
Dan
Old 07-30-2016, 11:58 AM   #6
If you have an A&E, Dometic, Awning, there are knobs on each lower arms that you can loosen and pull down the end of the awning to allow rain to drain off. This feature is also great for cleaning the awning.
tomrob1161 is offline   Reply With Quote
Old 07-30-2016, 12:20 PM   #7
Telstar's Avatar
If you have an A&E electric awning, drainIng I is automatic.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 07-30-2016, 12:25 PM   #8
IF it works. Not really a dependable system.
Old 07-30-2016, 12:54 PM   #9
You want to lower just one side (away from door) so the rain runs off there.
Epat is offline   Reply With Quote
Old 07-30-2016, 01:59 PM   #10
62_inrightlane's Avatar
The awning on our 2012 Berk has an auto dump feature plus the ability to tilt it with the buttons on the lower arm.
Only once did I see it do the dump feature. We almost never have the awning extended when raining. Was kind of neat. One side of awning rolled in like it was closing. After a foot or so it stopped and a flood of water flowed over the rear end of the awning. When it stopped the end of the awning went back to its normal extended position.
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 07-30-2016, 02:05 PM   #11
A really Great Idea would be if the OP listed the MFG and Type/Model#,or Pic of the Awning! It would keep down the "WAGs"! Youroo!!
Old 07-30-2016, 02:49 PM   #12
I have a 2011 and mine is automatic. It is wind sensitive and will automatically drain the water.
Old 07-30-2016, 11:32 PM   #13
That's really cool!
MarieP is offline   Reply With Quote
Old 07-30-2016, 11:54 PM   #14
The A & E (Dometic) is designed to dump water, and it works well, but I still drop one end of my awning so rain runs off the end I want it to.
Old 07-31-2016, 07:33 AM   #15
360true's Avatar
We have the same awning. I tossed a nylon strap over one corner and use a ground stake. Easier than breaking out the ladder to be able to tighten the knob and faster to undo if the wind picks up.
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 07-31-2016, 07:54 AM   #16
B and B's Avatar
Never had a problem with auto draining on my Awnings. As long as the adjustment nut isn't cranked down.
B and B
Old 07-31-2016, 08:06 AM   #17
Wolverine 1945's Avatar
No way would I trust the Auto Dump Sys,,,
I either strap both sides down as far as I can,,, or if I want the water to go a certain way I strap one end lower !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-31-2016, 09:06 AM   #18
Well I have had mine for four years and traveled from Michigan to Texas and Florida and New York. We have been in storms that have chased us to the club house for shelter. The awning rolls itself up when the wind blows hard and dumps when it rains. I almost don't even worry about it. I can set the sensitivity from low to high. Very good system and very happy with it. Now if they would have just put it on the slide so it gave some shade.
Old 07-31-2016, 10:11 AM   #19
CAT-RN's Avatar
X-2 to all that. Awning just to high. Auto dump and wind sensor work perfect !
Russell
CAT-RN is offline   Reply With Quote
Old 07-31-2016, 02:33 PM   #20
dan-nickie's Avatar
The auto dump works great. I was just showing it how to make it dump off the back end instead of the front by the door.
Dan
awning
