02-07-2017, 02:56 PM
Dragonship Captain
Balance Beads.....
Is anyone running balance beads in their steer (front) tires?
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
02-07-2017, 03:11 PM
Ret E-9 Anchor-clanker
One of my camping buddies uses then on his F-450. Towing a beautiful 40' 5r. It rides nice for the long haul but for sightseeing we use my F-250. I know when truck tires sit for extended periods they often get that flat spot but his feels like those bead things need ample time to find the right balance.
02-07-2017, 03:34 PM
Careful. I think most tire manufacturers void the warranty with beads.
2017 Puma 297RLSS
02-07-2017, 09:00 PM
I bought 6 new Michelin Tires in June 2016. Removed the external lead weights and installed beads in all 6. A very smooth ride. 5000 miles and I love them.
Pat
Cudntherd
2011 Berkshire 390BH-60
02-07-2017, 09:06 PM
Not necessarily, Here is Michelins service bulletin on the subject as it pertains to the type of tires that would be fitted on a Class A motorhome as per the OP's.
https://www.michelinb2b.com/wps/b2bc...gMaterials.pdf
Page 3 #9 of the Bridgestone warranty basically states the same as Michelin:
https://commercial.bridgestone.com/c...ANTY%20(1).pdf
2011 Flagstaff 831 RLBSS
02-08-2017, 08:25 AM
I have them in all 6 of my Michelin tires and love them. It took about 20 miles after the install for the bags to break and the beads to spread out like they are supposed to, but after that nice and smooth. I did verify that it will not affect the warranty prior to having them installed.
Glenn and Darcy
2018 Berkshire 39A
2016 Jeep Wrangler Unlimited/Blackbear (toad)
Pacific Northwest
02-08-2017, 08:58 AM
I had a balance issue with the fronts on my F550 running 19.5" Michelins. I got balance beads and problem gone. I wish I had put them in the trailer tires. There is no need to check to see if the balance weights are still attached.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
02-08-2017, 09:15 AM
Anyone use these Centramic balancers? If so, how are they?
https://www.amazon.com/centramatic-w...el%20balancers
Rich
"rolls down one hill, can 'ardly make it up the next..."
1999 21' Wildwood WDF21RK
2006 Dodge Ram 2500, 4x4, Quad cab, 5.9L Cummins, 3.73 gears.
02-08-2017, 09:42 AM
I think centramatic wheel balancers are a lot better had them on all the tractor trailers and they work great put them on and leave them alone had a million miles on a set
02-08-2017, 05:14 PM
Wow...that sounds like a good endorsement. Nice thing is, is that they're not inside the tires.
Rich
02-09-2017, 12:02 PM
I am curious if WMtire uses balance beads in his personal tires.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
02-09-2017, 01:10 PM
Although we install them in dually and larger mud tires, I don't really own anything personally that I felt like spending the money on since it's cheaper for me to use lead/steel weights. If I had a Class A or something that is hard/expensive to balance the tires on, I would most likely use the beads.
However, I have this relative (we have the same parents), who uses them on many of his two wheelers.
02-09-2017, 01:28 PM
I go RV'ing not Camping
Is anybody using these on their trailer tires??
My trailer of course currently didn't come with the wheels balanced from the factory, but these beads seem like a good idea.
My only concern would be letting out all the nitrogen to put in the beads and then having the tires leaking all the time when sitting with normal air in the tires.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
02-09-2017, 03:17 PM
Dragonship Captain
"normal air"? Oh man, I don't want to start this one again but you do know that "normal air" is 78% Nitrogen right?
02-09-2017, 03:19 PM
Dragonship Captain
Allrighty then, and before this thread goes off the N2 deep end (I know, I may have contributed to that)......
I ordered the Centramatics. I asked for the fronts only, but dude upsold me the rears. But, he threw in the shipping.
$414 for all four corners. And I can put them on in my driveway in an hour or so.
02-09-2017, 09:28 PM
2014 360 QL
centramatics, looks like the way to go. no mess when you have a flat repaired, and they take it off of the rim to repair.
2014 360 ql
02-09-2017, 10:32 PM
Dragonship Captain
Yup. And, no question about warrantee.
