Originally Posted by 5456Mich
It's a 2013 Hank. I do do a little research every once in a while.
Joe, I'm sure that your do a lot of research - good going!
When I took the front shroud/ bumper off I first had some trouble removing it around the head lights. The next big problem is that my instruction said to free four yellow plastic clips from behind the grille. After much time wrestling with that, I found that the grille could be released from the front side by inserting a thin screwdriver in a slot where the plastic clips were. the plastic clips are like a 1.5 inch square post that has different detention mechanisms on the fron and rear,
After getting the shroud off leaving the clips attached to the car, I removed the clips and inserted into the grille.
Hank
