Old 08-29-2011, 07:33 AM   #1
JEM
Batteries
I have a white power(LOT OF IT) on the strap buckle holding the batteries in place, I cleaned it once but is back. How do I get rid/prevent it.
Model 390bh, 2011
JIM
JEM is offline   Reply With Quote
Old 08-29-2011, 07:43 AM   #2
KyDan's Avatar
You can get battery cleaner spray at Autozone or the automotive isle of many
dept stores. Baking soda mixed with water applied with an old paint brush will
also neutralize the corrosion.
If your batteries are located where you can flush the tops with water, that
is a big help. Wear old clothes!! As you may already know, just one tiny crumb of
the battery corrosion on your clothes will result in holes!
OTOH some folks pay extra for jeans with just those types of holes in them!!
Clean them, flush them, clean them again.
Painting the buckle strap with a good quality paint like Rustolemum will help
also. Bare metal around batteries is going to corrode.
Paint can slow it down but it's gotta be pretty clean first.
Good Luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-29-2011, 08:11 AM   #3
Boyd's Avatar
My experience with corroded battery terminal causes has been failing battery and/or loose connections.
Remove cables, clean with round file and wire brush. Apply specific anti-corrusion substance or Vasoline and re-attach. A shot of WD-40 now and then is also a deterant to corrosion.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 08-29-2011, 01:24 PM   #4
tmmar's Avatar
I had the same problem with my coach. I ordered several Battery Mats (Acid Neutralizing Mat: BatteryMart.com) and placed them under the bottom band of batteries covering the entire bottom of the compartment after I cleaned off the corrosion. I also put 1.5 oz of mineral oil in each cell of the battery. I not longer have the problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 08-29-2011, 03:48 PM   #5
2011 Berkshire 390bh
wnytaxman's Avatar
Thanks Tom and Boyd. I also have the same problem. I'll give your suggestions a try.
wnytaxman is offline   Reply With Quote
Old 08-29-2011, 03:56 PM   #6
leencharlotte's Avatar
In the past I used marine grease on the terminals. Never corroded again for years. My car dealership put some kind of red colored grease when I purchased my new vehicle and no problems as well. Wd40 will work as well just doesnt last as long
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
battery
