Old 05-05-2012, 08:42 PM   #1
kingwood390bh's Avatar
batteries dead again
I have a Magnum MM-1212. 1200 watt continuous modified sine inverter/converter on my 390bh. I have it stored indoors plugged in to 50amp service. I had the chasis batteries turned off and the house batteries turned on. My assumption was that the house batteries would charge since it is plugged in and the chasis batteries would remain charged since they were turned off(two weeks ago). So today I returned to find both sets of batteries dead. The Magnum remote indicated a "low voltage fault" by blinking once every 4 seconds. None of the interior lights come on(I think they are fed by the 12 volt system). Also, interestingly, the microwave/convection oven seems to work just fine. I just put the chasis batteries on a battery tender so I can start it tomorrow. What did I do wrong?
kingwood390bh is offline   Reply With Quote
Old 05-05-2012, 08:59 PM   #2
VinceU's Avatar
Seems the 115 VAC is on and connected, it also appears its feed to the converter portion of the Magnum is interupted or the Magnums output fuse or brk for the 13.6 volt DC is open. Could be either fuse or CB, not familar with that device. With the converter working or connected you should have interior lights even with dead batteries. This will give you a start hopefully. Both supply and output of the Magnum could be at fault.
Old 05-06-2012, 12:59 PM   #3
Update; I went back this morning after leaving the chasis batteries charging all night. Engine fired right up. Using the aux start button, I started the generator. I left everything running for about an hour, and when I left, the house batteries were fully charged and the "fault" indicator was off. I then turned off the Magnum from the remote, disconnected the battery from the front of the coach and shut off both sets of batteries from the battery compartment. I did not plug in the 50amp service. Lets see how this works. Also, where is the mechanism to open the generator door?
Old 05-06-2012, 01:04 PM   #4
papap's Avatar
I know on mine if you check the batteries to see if they are charged while the generator is running. They will show full charge even if the are not. You have to check the panel when it is turned off and not hooked to shore power.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 05-06-2012, 01:42 PM   #5
tmmar's Avatar
In the outside fuse compartment which is under the drivers seat you wil see a black 'T' handle. If you pull it, the generator compartment will open. To close, just push the generator back in until it locks in place.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 05-07-2012, 12:48 PM   #6
Update: Spoke to the Magnum rep this morning. He suggest that the fault may lie in path from the shore power to invereter. The romote should indicate "ac in" whenever the unit is plugged in. I did not have that. I have to locate the circiut breaker that is tripped to fix the problem. He says that the system is fully automatic and that when working properly, the Magnum will charge the house batteries till full, then charge the chasis battery, then float charge to keep all batteries at optimum. I told him I wish there was a video to explain the system. Is there a panel in the coach with circuit breakers?
Old 05-07-2012, 01:00 PM   #7
Director, FROG
F.R.O.G.'s Avatar
Do you have the manual for the Magnum MM1212? If not, you can get it here:
http://magnumenergy.com/Literature/M...%20Series).pdf
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 05-08-2012, 12:06 AM   #8
One thing I found with mine, although it is probably not the cause of your troubles, is that my battery connectors were crimped poorly are the factory. So, in essence only 1-2 of my batteries was actually connected, so things wore down quickly. New crimps (and of course I upgraded the batteries while I was at it) and all is good. Worth checking if all else fails.
2011 390BH
MotoWood is offline   Reply With Quote
Old 05-13-2012, 12:26 PM   #9
Update: Went back to the coach yesterday, having left the unit unplugged and batteries turn off in the rear compartment. Engine started and the house batteries still indicated full. I found the "power center" and none of the circuitbreakers had been tripped. Oddly, upon leaving, I tried to switch the front battery disconnect to store but it was unresponsive. I rocked it up and down yet it remained lit. I shut the batteries off in the rear compartment. Next week I'll return to plug it back in. If the "ac in" lights up on the inverter remote then most of my problems are resolved. If not, I still have to find the problem from shore power to inverter.
Old 05-13-2012, 01:15 PM   #10
Herk7769's Avatar
An hour will not "fully charge" your house batteries. It most likely brought it up to about 50% capacity on the fast charge part of the cycle but that "surface charge" voltage will drop off about an hour after you switch them off. After an hour disconnected; check your batteries with a voltmeter to get an accurate "state of charge" according to the chart below.
Name:	Charge Chart.jpg
HAM CALLSIGN - KC3FFW
led pad, battery
