Old 03-23-2014, 08:34 AM   #1
gasman94's Avatar
Battery boost switch
Has anyone else noticed a faint flickering glow from the battery boost switch light without the key on and the coach not running? Don't know if this is normal or an electrical glitch. None of the other switches demonstrate this behavior. It happens if I have the radio on.
gasman94 is offline   Reply With Quote
Old 03-23-2014, 08:50 AM   #2
Rrickim63's Avatar
I wouldn't worry. Many circuits back feed a little voltage which would make it glow.
1999 Silverado with tow package
2006 Roo 23B hybrid
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 03-23-2014, 09:26 AM   #3
gasman94's Avatar
Thanks Rrickim63. I currently have a generator that won't start so I just wanted to be sure that this wasn't related.
Old 03-23-2014, 10:00 AM   #4
Berkshire 390QS
NO3putt's Avatar
ours does the same thing and from previous thread many do the same.
Old 03-23-2014, 10:03 AM   #5
silver's Avatar
Mine and my buddy's does this also.
My buddy had a problem with his generator and it turned out to be a fuse in the controller board inside the generator. You may want to check the manual see where it is and check it.
Do you know if you hold the generator switch off that this primes the gen in the event that is the issue.
silver is offline   Reply With Quote
Old 03-23-2014, 10:14 AM   #6
gasman94's Avatar
Silver, no prime/no noise. I'm getting a code 17 which I think is a fuel pump problem. I'm bringing it to the factory next month for my list of first year issue/repairs and will have it taken care of then.
Old 03-23-2014, 10:44 AM   #7
NV245's Avatar
The light glows when the batteries are 13.3 volts or above, allowing the battery isolator relay to close and both coach and chassis batteries are in parallel for charging. When battery voltage is below 13.3 volts, the relay will open so all batteries will not be discharged. Below 13.3 volts, the glow will be out and coach and chassis batteries will be isolated unless the aux start switch is closed.
NV245 is offline   Reply With Quote
Old 03-23-2014, 11:00 AM   #8
gasman94's Avatar
Thanks. Since I keep my batteries constantly charged with battery tenders, this makes sense.
Old 03-23-2014, 03:52 PM   #9
tmmar's Avatar
Had the same thing happen on my '08 and also on my '14. As far as I can tell, it is not a problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-23-2014, 06:03 PM   #10
RKC02's Avatar
Gasman94: i have the same code 17 on my genny which also won't start- no prime or any noise at all. Thought it was fuel pump but turned out to be a software issue requiring an upload to version 2.39 to fix the 'nuisance code 17) problem. Note: Freightliner will Not do this repair. Has to be an authorized Cummins dealer. I'm stopping at one in Spartanburg, SC on my way to the factory for service and the class.
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
battery
