Old 10-01-2012, 04:36 PM   #11
tmmar's Avatar
You should at least wipe down the affected areas with a water/baking soda mixture to neutralize the acid build up and then spray it clean with water. You will also need to do something to prevent the build up from coming back because if you don't do anything, the corrosion build up will come back.
Tom and Margaret
2014 Berkshire 390bh-60
battery
