Old 01-27-2014, 03:23 PM   #1
tmmar's Avatar
Battery meter on dash fluctuates
I noticed the other day when I start the coach after it has been parked for a few days that the battery meter fluctuates from about the 12v area to the 14v area. The needle moves back and forth about 12 times and then it stops and settles in at just over the 13v line. Anyone else notice this happening? Not sure what is happening.
Thanks for any suggestions.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-27-2014, 03:36 PM   #2
JTN8's Avatar
Mine does the same thing... Then settles out and doesn't do it anymore. Seems like the alternator is cycling on and off when the coach firsts starts up and then it's good.
Old 01-27-2014, 03:43 PM   #3
Campin Cajun's Avatar
Mine does the same and if I am parked for more than 3 weeks it will give me the low battery warning also. After a few minutes of running the warning goes away.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-27-2014, 03:43 PM   #4
tmmar's Avatar
JT-
I thought the same thing, that it could be the alternator cycling or I also thought that it could be electrical components coming on line, one after another.
Hopefully it won't turn out to be a problem later on.
thanks,
Tom
Tom and Margaret
Old 01-27-2014, 03:47 PM   #5
JTN8's Avatar
Originally Posted by tmmar View Post
JT-
thanks,
Tom
Probably makes more sense that the components are
Coming on line. I agree, hopefully this is just normal and won't be an issue later.
Old 01-27-2014, 04:03 PM   #6
Would believe it's the voltage regulator adjusting the current going into the battery.
Old 01-27-2014, 05:51 PM   #7
Cyclone
beipers's Avatar
How cold was it? Did manifold heater light show while you were cranking the engine? If so, the voltage level will fluctuate as the Cummins Engine ECU cycles the heater directly after start up.
2015 SOB 5th Wheel
2013 Chevrolet 3500 CC, DD SRW
1 Wife, 2 Kids under 5
Camping nights: 2015 - 19, 2014 - 39, 2013 - 48
beipers is offline   Reply With Quote
Old 01-27-2014, 06:20 PM   #8
Mmnsc's Avatar
Tom
Freightliner told me it was normal as the system needed to warm and draws current as it cycles. Made me nervous at first. I hope you had a nice warm day.
Mmnsc is online now   Reply With Quote
Old 01-27-2014, 06:24 PM   #9
tmmar's Avatar
Marty,
Thanks for the info. Yes, temp in 70's and sunny. Hope you don't get hit too badly with the storm. Keep us informed.
Tom
Tom and Margaret
Old 01-28-2014, 07:28 AM   #10
2013 Berkshire 390 BH-60
Jersey Guy's Avatar
This must be a Cummins thing, my Berk does it as well as my Dodge p/u with the 5.9.
Mike
2013 Berkshire 390BH-60
Jersey Guy is offline   Reply With Quote
battery
