Old 08-07-2013, 12:46 PM   #1
410 QS 425 2011 Birkshire
Bed room headboard slideout
My bed room headboard slide will not pull in fully,it jerks but will not keep it tight. Out is fine . In the process of taking it apart as you can't see the motor or gear work
malewis49 is offline   Reply With Quote
Old 08-07-2013, 11:08 PM   #2
This is a known problem. Check the mounting bolts on the slide motor that is under the bed. The best accessibility is with the slide extended.
cudntherd is offline   Reply With Quote
Old 08-11-2013, 04:20 PM   #3
Checked the mounting bolts and they were loose,tighen and the problem is fixed thank agains.
Old 09-26-2013, 02:58 PM   #4
Just finished tightening mine after the slide would neither go in or out.
The slots used for adjusting are just barely long enough to raise the motor enough so the pinion gear engages the rack. I may have those slots elongated a bit if it happens again, so that I can make sure the pinion is completely engaged in the rack.
Has anyone heard a "story" about why FR used a combination of THREE different systems to move slides; specially when cable are supposed to be the most troublesome??
I've heard it has something to do with a contract signed many years ago that stipulated that every coach FR built had to have a LEAST one cable moved slide. Anyone able to confirm this?? It sounds bizarre to say the least.
Boowho??
boowho is offline   Reply With Quote
bed, roo, slide, slide out
