Originally Posted by EJM4
The motor in bed slide loosened and dropped down not allowing to move. You remove the screws from the panel and access the motor.
Thanks for all the replies..... It MAY be a shear pin, but in my initial inspection it appears the motor has dropped enough (loose bolts??) that the pinion no longer engages the rack.
It's gotten pretty hot here in Las Vegas, so will not try the actual adjustment until tomorrow AM.
Boowho??
