Old 08-20-2016, 12:36 PM   #1
gasman94's Avatar
bed slide cables adjustment
I've got a '14 390fl and have a lot of slack in the bed slide cables. Last time bringing it in, it's starting to sound a bit noisy. Anyone know how the tighten these? The area above the bed is wood trim. Thanks.
Rich
gasman94 is offline   Reply With Quote
Old 08-20-2016, 01:03 PM   #2
AquaMan's Avatar
You have to remove the wood trim board. There are screws under the little plastic screw covers. You may have other problems going on though. Are the cables loose on just one side, inside, or outside? Hopefully it's just an adjustment.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-20-2016, 01:40 PM   #3
gasman94's Avatar
All four cables are loose. Adjust from top?
Rich
Old 08-20-2016, 08:26 PM   #4
dan-nickie's Avatar
Rich, I guess you know that you're supposed to be just a little slack in the cables?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-21-2016, 06:43 AM   #5
AquaMan's Avatar
My cables, and all the ones I've seen, have been tight in both directions.
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-21-2016, 06:44 AM   #6
AquaMan's Avatar
Rich
Yes, the adjustment turnbuckles are above and behind the trim
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-21-2016, 08:40 AM   #7
gasman94's Avatar
I'll check it out today. Two turnbuckles? Adjust both? Thanks!
Rich
Old 08-21-2016, 09:10 AM   #8
dan-nickie's Avatar
http://www.doityourselfrv.com/adjust...-driven-slide/
Dan
Old 08-21-2016, 09:41 AM   #9
gasman94's Avatar
Thanks Dan. Just downloaded the manual.
Rich
Old 08-21-2016, 04:29 PM   #10
gasman94's Avatar
Just adjusted the cables. Hope I did it right. On my model (390fl) the bed must be lifted, slide extended and they are below the bed back against the wall.
Rich
bed, cable, slide
