Old 03-05-2015, 05:10 PM   #21
After almost two years (and 4-5 fixit attempts), that damn slide is STILL causing me trouble.
I bored out the casting and "thru-bolted" it so I could apply more torque without stripping out the housing.
I need to probably put blue locktite on the nuts, or maybe use elastic stop-nuts instead.
Randy, seems to think the the bolts/nuts are coming lose with just a few uses; he mentioned something about star washers, which mine does not have.
Best luck I've had so far was the hydraulic jack (as mentioned earlier) but after a couple thousand miles it worked itself loose.
Boowho??
boowho is offline   Reply With Quote
Old 03-05-2015, 06:21 PM   #22
jmgllt's Avatar
It seems to be a design flaw. FR needs to do a reengineer on this!
jmgllt is offline   Reply With Quote
Old 03-06-2015, 08:47 AM   #23
silver's Avatar
I was thinking about this bed motor slipping problem. On my coach I built a support base of 2x4 and a v block to hold the motor that has worked great. The one problem is I had to fuss a lot to get the height correct and I have no height adjustment.
My thoughts using common parts from the hardware store a support bracket could be fashioned that would allow for height adjustment by turning the main support shaft. I guessed at the diameter of the motor as my coach is in storage. Hopefully you all will get the idea.
Name:	Bed Motor Support.jpg
silver is offline   Reply With Quote
Old 03-06-2015, 09:31 AM   #24
WOW!!! I've been thinking of something like that for a long time. Just couldn't go from the "I wonder if..." stage to an actual design with REAL part numbers.
How 'bout replacing the threaded rod with a monster turnbuckle to provide for adjustment??
This takes my hydraulic jack idea to the next level!
Boowho??
Old 03-06-2015, 09:32 AM   #25
tmmar's Avatar
Looks like it might be a great solution for an ongoing issue. Thanks for sharing.
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-06-2015, 02:09 PM   #26
silver's Avatar
Boowho??
Yes I got my original block Idea from you.
I looked for a turnbuckle as you suggested but would need one with 3/8 threads and 4 inches long. All the turnbuckles I found in the box stores were 8 to 10 inches long. I wanted to keep it to box store parts. So the Idea I presented is my second choice.
Bottom line need a saddle to hold the motor and something to hold up the saddle.
Further thoughts may want to place a stop nut under the hanger so the thread rod cannot hit the motor.
Old 03-07-2015, 01:45 PM   #27
FWIW, the motor measures 2.5 inches in diameter.
Boowho??
Old 03-07-2015, 07:50 PM   #28
silver's Avatar
Boowho??
Hi Boowho,
Thanks for the motor measurement. I do not have access to my coach to make the measure. New Idea for motor support. Should accommodate the larger diameter and stay with box store material. Just my idea.
Old 03-08-2015, 09:12 PM   #29
Hi Boowho,
Whole new direction...... Get some aluminum bar stock 1 inch wide and .25 thick. Cut off 2 pieces that are 2 inches long. Bore hole in each.
Then lay flat against the frame with one end contacting the bolt head coming thru from the motor.
Bore hole in the main support frame that aligns with the hole bored in the aluminum stock piece. Put bolt thru and tighten well.
Slide motor can no longer slip as the two aluminum blocks will not allow the motor mounting bolts to move downward at all. The block mounting wholes are NOT slots, but the exact same size as the bolt.
Voila????
Boowho??
Old 03-09-2015, 07:24 AM   #30
silver's Avatar
Hi Boowho,
Another good simple idea. Bar stock would bolt against the bottom two bolts I assume? Need to be careful to drill holes below the motor gear box. Would not want to drill into gear box and have another problem.
It is a great place to work isn't.
