Old 05-03-2015, 12:50 PM   #1
Bedroom Light Problem
The under cabinet lights and reading lights over the bed in our 2010 Berkshire have stopped working. The ceiling lights and closet lights are working fine. I've checked every fuse I could find. Anyone got any ideas on what might be the problem? Thanks
2014 - 240 days of camping
2015 - 210 days of camping
2016 - 265 days of camping
2017 - 244 days of camping
RNuzzolo is offline   Reply With Quote
Old 05-03-2015, 01:29 PM   #2
fonzie's Avatar
Have you check the bulbs?
Fonzie
Old 05-03-2015, 02:11 PM   #3
tmmar's Avatar
Have you checked the GFI outlets? The lights may be wired through on of those. I would reset all the GFI outlets to see if that helps.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-03-2015, 02:29 PM   #4
12 volt, try an 1156 bulb.
Mike
mcomer is offline   Reply With Quote
Old 05-03-2015, 02:50 PM   #5
Herk7769's Avatar
Mike
The fact that more than one light is involved leads me to think:
1) Fuse (which you checked)
2) Wire nut separation (wire pulled out of nut). Look at all the light connections starting at the last one that works and moving back to the bedroom. You might find a loose or missing wire nut and a hanging wire (happens).
HAM CALLSIGN - KC3FFW
Old 05-03-2015, 03:03 PM   #6
I did not check the bulbs but I will. Seems strange that all 4 would go bad at the same time but it's worth a try. Thank you
Old 05-03-2015, 03:04 PM   #7
I'll try that. Not something I even considered. Thank you
Old 05-03-2015, 03:05 PM   #8
Also a good idea. I'll try that tomorrow. Thanks
Old 05-03-2015, 04:01 PM   #9
The two reading lights above the we're not working on mine when I first got it. Did not look on pdi. So I figured I have a wiring problem. Checked fuse and all the pulled the shelf up inside cabinet and power. So I checked the bulb, it was bad. I just hate to admit that I tried the easiest thing last, especially to wife. Lol
Mike
Old 05-05-2015, 04:07 AM   #10
After checking bulbs, GFI's, and wires I decided to recheck the fuses and sure enough I had a bad fuse. Thank you all for your replies and ideas.
bed, light, roo
