Old 01-04-2016, 09:26 AM   #1
Bedroom Television
Has anybody changed out the television in the bedroom. We have the BH model and just can't get my hands behind the tv. The unit does tip from the top but I'll be damned if I can figure out how to get it off.
Paul
Paulie Boy is offline   Reply With Quote
Old 01-04-2016, 09:33 AM   #2
KennyGolub's Avatar
Been trying to figure this one out also.
Gonna sit back and watch the answers
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 01-04-2016, 10:03 AM   #3
On our 2011BH the rear TV is on a "slide on" mount. Just hold the bottom of the TV and push it up to get it off the mount.
Pat
Cudntherd
2011 Berkshire 390BH-60
cudntherd is offline   Reply With Quote
Old 01-04-2016, 10:03 AM   #4
accumack's Avatar
I had to take mine off to run an HDMI cable for a dish box a couple of years ago. It was a pain to reinstall. If I remember correctly the release is on the bottom and you slide the TV up.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 01-04-2016, 01:46 PM   #5
Subsailor's Avatar
Just had mine off the mount last weekend. I have a 2013RB and not sure if it is the same, but there is a screw "lock" in the middle of the mount on the bottom (just behind the actual TV that you take out. You then pull the bottom of the TV forward and lift up to get the "hooks" on each side off of the rail they rest on near the top. Hope that helps.
-Glenn
Glenn and Darcy
2018 Berkshire 39A
2016 Jeep Wrangler Unlimited/Blackbear (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 01-04-2016, 02:13 PM   #6
ceedog's Avatar
On my 2011, there's a release handle at the bottom (center). Just squeeze & it comes off.
It ain't easy being me...I've tried.
ceedog is online now   Reply With Quote
Old 01-04-2016, 04:10 PM   #7
Thanks for all the comments. Of course my set up is nothing like any of you described. Through much frustration, trial and error success. Take a seat! After looking for all of the suggestions I found out that I had to remove the window valance to access two Allen set screws that secure the television to the wall mounted hardware. The valance is only held on with three screws but the screw on the top, #2 Robertson requires about a 6" extension, and we all have one those just hanging around.
Paul
Old 01-08-2016, 11:07 AM   #8
BamaBob's Avatar
OH GOOD GRIEF Paul! You would think they would have made it easier than that!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 01-08-2016, 11:22 AM   #9
You would think! They didn't though!
Paul
Old 01-08-2016, 09:48 PM   #10
We have a 2012 390BH60. I swapped out the rear TV the first year to a much larger unit.
To remove I think there was a release pin or lever and then lift off.
I installed a power bar into the single outlet behind the TV. Fill thee hole behind TV and reinforce. Install an articulating arm with a larger TV that will fit flick to cabinet face frame. I installed a small shelf below TV to house a new blueray player and sound bar.
The TV is locked in ticht to cabinet for travel and is pulled out and tilted when stopped.
I have it wired in to either play the same DVD as living room or the bluray in rear.
Total cost was approx 300 dollars.
lefaivre is offline   Reply With Quote
Old 01-09-2016, 09:45 AM   #11
Subsailor's Avatar
Hi Lefaivre, could you please post a couple pictures of your install? I am interested in possibly doing something very similar. Thanks, Glenn
Glenn and Darcy
2018 Berkshire 39A
Pacific Northwest
Old 01-10-2016, 08:27 AM   #12
Finished changing out the bedroom tv. Learned Toshiba pulled out of the US market. If you find a Toshiba, it's made by some other company. Ended up with a Samsung Smart TV. After figuring out how to uninstall the original TV the install was a breeze.
Paul
2014 390 BH-60
2015 Jeep Wrangler Unltd. Sahara
Old 01-12-2016, 03:21 PM   #13
Paul
2014 390 BH-60
What size did you but in. I'm about to upgrade both TV's.
Old 01-12-2016, 04:09 PM   #14
I only had room for 32" in the bedroom. Got a Samsung Smart TV for $229 + tax at Best Buy.
Old 01-12-2016, 05:52 PM   #15
Subsailor's Avatar
Paul, would you please post a pic of the install? Like Phil I am really thinking about doing this because my old eyes have trouble seeing the current smaller TV while laying in the bed. -Glenn
Glenn and Darcy
2018 Berkshire 39A
Pacific Northwest
Old 01-12-2016, 07:50 PM   #16
Name:	ImageUploadedByForest River Forums1452645971.827183.jpg
Sorry Glenn, this is the only picture I took. The Allen set screws are accessed by the holes you see drilled under the attaching arms. The window valance is held on by three screws. One left, right and one center top. If you go with Samsung, you'll need to buy four m8 x 35mm machine screws and lock washers, split washers.
Paul
2014 390 BH-60
Old 01-12-2016, 09:14 PM   #17
The 2012 has two overhead cabinets above dresser. The original fit between the two with room.to spare.
The replacement is.not huge but I think I went from.about 18 to a 28.
The new one fits nicely in front of the face frame with a shelf and blurry with soundboard down below.
Will.input photos the next time I go out to storage.
Old 01-12-2016, 10:19 PM   #18
Ive mounted numerous flat screens and many that are non swivel come with a 12-18" T handle Allen or just a plain 90 degree bend Allen. Harbor freight should have what you need if your trying to get off on the cheap for a tool to remove the bottom set screws.
getsum is offline   Reply With Quote
Old 01-13-2016, 07:26 AM   #19
Neither do any good if you don't take the window valance down. The head of the Allen set screw is below the top surface of the trim piece.
Paul
2014 390 BH-60
Old 01-13-2016, 10:41 AM   #20
BamaBob's Avatar
Glenn....PLEASE, give all of us a break brother!!
bed, roo, television
