Old 07-19-2014, 08:49 PM   #11
mshell56118's Avatar
Not sure where u are located but call a cummins distributor shop and give them the serial number they should be vale to tell you warranty status. And if out of warranty more than likely be able to do it cheaper or even work a little more with you.
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 07-19-2014, 09:09 PM   #12
Originally Posted by boowho View Post
That tesioner has GOT be covered under the Cummins warranty, at least IMHO.
I've decided that FL spends more time TELLING us what great CS they offer, rather than actually offering it. I love my FL chassis, but am not all that happy with the company itself. They did step up to the plate on replacing my defective shift controller box, however.
If you can get Sean on the line at CS, you've got a better chance of success, (again) IMHO.
Boowho??
As I mentioned earlier, mine was replaced twice and covered under the Cummins warranty without issue, the last time about 4 1/2 years into the warranty. Had to pay the deductible but still cheaper when labour factored in. This IS a covered part.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 07-19-2014, 09:21 PM   #13
Does anyone know of a Cummings dealer on Long Island
michell-n-scott is offline   Reply With Quote
Old 07-20-2014, 07:26 AM   #14
tmmar's Avatar
Mitchell,
Not sure where there is a Cummins dealer on LI but there is a Freightliner Dealer/service center on Lakeland Ave in Bohemia. It is called TRUX or Freightliner of Long Island. The work they do is very good.
Good luck,
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-20-2014, 08:13 AM   #15
You had work done on your RV there? I bought some parts from them once didn't realize they would work on the RV
Old 07-20-2014, 08:46 AM   #16
Berkshire 390QS
NO3putt's Avatar
We take ours only to frightliner or a cummins dealers for engine or chassis work, odds are a RV dealer won't know how to fix in the first place or how to do it right.
Old 07-20-2014, 10:27 AM   #17
tmmar's Avatar
Mitchell,
Yes, I have had warranty work done there as well as some maintenance (chassis lube) and NYS inspection.
Tom
Tom and Margaret
Old 07-20-2014, 12:53 PM   #18
That's great news I'm going to call them up and make an appointment.
Old 07-20-2014, 08:56 PM   #19
silver's Avatar
If the tension-er is bad what the shop may not be telling you is that there is burned rubber from the belt on all the pules. If you do not clean them off the belt will slip, squeel and give you constant problems. I know because the first time mine was changed FL did a quick and dirty job under warranty. The second time was out of warranty. Cost about $2000. I was there for the entire job and the tech earned every penny. Took two days to clean things up and at one point the thought was might have to replace the water pump and AC pump. You would not think so but It was a real mess. FL near me really Scr$$ed me on the first repair.
silver is offline   Reply With Quote
Old 07-21-2014, 09:15 AM   #20
Good to know I will watch as they do it
