Old 01-29-2016, 06:48 PM   #11
Originally Posted by Campin Cajun View Post
There's a little iron spacer on that pin, it has a slit in it. Take a screw driver and pry it out a little.
That is how I have always fixed mine. Just spread the roller a bit with a flat screwdriver. I tried it last week on mine again and it seems to not be working now. Not sure what's up but will look at it later.
Old 01-29-2016, 07:16 PM   #12
dan-nickie's Avatar
I see the spacer and will try that tomorrow.
I just wrapped a little duck tape on it for now.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-30-2016, 08:02 AM   #13
I-RV's Avatar
Dan, I would advise on doing that. I pried the barrel spring and a piece dropped out. The barrel spring is high tempered and will not take bending. I had to have the total arm replaced back when I was under warranty.
I am not sure if the design has changed, but I found that the barrel spring had a rivet to the round barrel that it surrounded and that probably is where the weakest link is. I do not know of a fix other then replacing.
Not a very good design; even my new one has a mild wind, closing the door. Opening hard against the stop also shortens its life.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
door
