Old 05-27-2016, 08:28 AM   #11
gasman94's Avatar
Originally Posted by CAT-RN View Post
Mine did not have any bracket across the top.
Russell
Russell, I checked mine yesterday and didn't see a bracket on top. In fact, I added a bracket to the side because I had one instance where the fridge wanted to come out during a turn.
Rich
gasman94 is offline   Reply With Quote
Old 05-27-2016, 09:17 AM   #12
tmmar's Avatar
Dan,
Was the bracket attached to the refrigerator or just to the trim?
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 05-27-2016, 09:50 AM   #13
tmmar's Avatar
Rich,
Sounds good to me!!
You have a great holiday as well.
Tom
Tom and Margaret
Old 05-27-2016, 10:38 AM   #14
dan-nickie's Avatar
Originally Posted by tmmar View Post
Dan,
Tom
It was half ass glued to the top of the refrigerator also but really wasn't holding anything. I put some double stick tape on it when I reinstalled it.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-27-2016, 03:29 PM   #15
gasman94's Avatar
Ok I've pulled mine twice. Once whirlpool had a tech do it and once I did it.
After you pull the plastic cover under the freezer door you will see a height adjustment device on each front corner. These are screwed into the floor with two or three small wood screws each. And then screw onto the frig with four screws.
Remove both those levelers and then you can slide frig out. This thing is tight in the hole!! There is plenty of water line and electric cord to get it out.
The tech had a piece of 1/8" plastic that he laid down to set it on. I pulled it out last winter and put new carpet in coach. I just slid it out onto the tile. Worked ok. It is so tight a fit that it will take two people to move it I would guess.
Mine is an FL.
Russell
Got the fridge out. Thanks for the info on the wood screws. I'd still be trying to pull it out. Came out fairly easily after that. Had to shimmy out through the tight space. Part is coming tomorrow so I'll replace it then.
Rich
Old 05-27-2016, 05:38 PM   #16
Rich
Rich I called Whirlpool about 2 months ago I guess and couldn't get them to come out and do the change be the guy said he would send me the part at no cost, which I rec'd. about 3 weeks ago. Haven't had any problem with it yet, just wanted the upgrade. So I have the part and wait for if and when it starts to leak.
Joe
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 05-27-2016, 06:02 PM   #17
Berk fridge leak
Silly philosophy Joe, it's like the roof leaks when it rains. But, no need to fix it when it's sunny because it's not leaking.
2015 XL 40QL
Paulie Boy is offline   Reply With Quote
Old 05-27-2016, 06:55 PM   #18
2015 XL 40QL
I don't see it as the same. When it starts to leak ( the fridge ) it will always leak whether it's raining or not.
Joe & Lori
Old 05-28-2016, 10:50 AM   #19
Just change the damn "P" trap before it starts leaking and be done with it🤓😜
2015 XL 40QL
Old 05-28-2016, 02:21 PM   #20
gasman94's Avatar
Just finished. Not as bad as I thought. Did all of the work myself. Thanks for all of the advice. Boy, that space is tight.
ID:	109350   Click image for larger version
ID:	109351   Click image for larger version
ID:	109352   Click image for larger version
ID:	109353   Click image for larger version
ID:	109355   Click image for larger version
fridge, leak
