Old 03-08-2016, 08:57 PM   #21
ernest917's Avatar
Only had to remove marker light, fog light and parking light.... That's what has me stumped.... No blow to fuses, etc... Again - everything worked perfectly when I dropped it off....
It sat there for three weeks not plugged in so I'm wondering if batteries are dead....
ernest917 is online now   Reply With Quote
Old 03-08-2016, 09:01 PM   #22
NV245's Avatar
Did you check upper left in compartment, that has the chassis power distribution? Also, recheck ignition switch positioning. Again, did HVAC work?
NV245 is offline   Reply With Quote
Old 03-08-2016, 09:19 PM   #23
ernest917's Avatar
HVAC won't work unless in plugged in or on generator... Right?? Dash defroster worked fine.... None of my switches at front entry work plus my smart panel (water pump, interior lights, etc) doesn't work
Old 03-08-2016, 09:20 PM   #24
ernest917's Avatar
What's in upper left ?
Old 03-08-2016, 09:38 PM   #25
NV245's Avatar
Sorry, I meant chassis HVAC (dash controlled). Upper left of power cabinet is where the chassis fusebox and relay center is. For water pump and coach lighting, yes, coach batteries may have been discharged, but you should still have wipers and running items from the chassis system. Usually, the dash HVAC control has a separate side of the ignition switch from the other(wipers and radio) and the engine run feed. After charging the coach batteries, you may want to check and see if the radio will work with the center console radio switch turned on. I'm trying to determine if you have power to and from the ignition switch for the accessories. Also, check if the overhead TV turns off when the ignition is turned on.(Also assuming the coach is plugged in or generator running)
Old 03-08-2016, 09:42 PM   #26
ernest917's Avatar
I had full running lights, turn signals and low/high beams..... All dash lights worked as well as all
Old 03-08-2016, 09:44 PM   #27
ernest917's Avatar
Switch lights, except for the wiper light worked as well....
Old 03-09-2016, 07:23 AM   #28
silver's Avatar
earnest
Your picture showed the metal in front of the electrical door distorted so they had to work around the door.
Once the coach was running the alternator should have compensated for a low battery and run things.
I would check the electrical compartment. Inside and out. Might also ask the shop if they disconnected anything there while working.
Just my thoughts. Always something. I hate leaving my coach at the shop for this very reason. More work to do when you get it back than when you left it. Frustrating.
silver is offline   Reply With Quote
Old 03-09-2016, 09:23 AM   #29
ernest917's Avatar
Well charged batteries over night and..... everything's working... Except I can't get my camera screen to deploy.... Will ck that out later today....
Old 03-09-2016, 10:16 AM   #30
NV245's Avatar
Great! I did have the same problem with my rearview camera screen, opened the dash cover, unplugged the radio, left it unplugged a minute, plugged it back in and it was reset. I don't understand how the coach batteries affected the wipers and radio, but glad the problem is gone.
