Old 03-03-2016, 06:56 PM   #1
MLnDavo's Avatar
Berkshire
Are the problems with new Legacy headlights also a problem on new Berkshires?
MLnDavo is offline   Reply With Quote
Old 03-03-2016, 06:58 PM   #2
oldkeywest91's Avatar
what is the problem with head lights?
oldkeywest91 is offline   Reply With Quote
Old 03-03-2016, 07:14 PM   #3
MLnDavo's Avatar
Saw a few people complaining that Legacy headlights were insufficient.
Old 03-03-2016, 07:32 PM   #4
RKNOLA's Avatar
Yes, the Berkshires lights can be a little dim. Some owners have changed the bulbs to a Sylvania Silver Star 9006. It is a bright white bulb that supposedly makes a big difference. We haven't done it to ours yet, but DH planning on it.
Karen
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 03-03-2016, 08:19 PM   #5
Changed over to the SilverStar bulbs and changes from night to day.It is a very easy change reaching in thru the gen.opening.Just remember not to touch the glass part of the bulb as oil from your skin could cause the bulb to break when light is turned on and cooks the oil.It is just a matter of turning the base of the bulb to remove it from frame then unplug the harness,then reverse the process to replace.save the old bulb as a spare if one should burn out in the future.We do a lot of driving at night to avoid traffic between NJ and FL. and the new lights make it much easier to see at least 4 to 5 times the distance of the stock bulbs.
Old 03-03-2016, 11:59 PM   #6
7 Year Class A RV'er
Oldkeywest91: Can you tell me what the bulb number, etc. is in your Berkshire? I'd like to check my Legacy and see if it's the same do I can look into the Silver Star replacement. Thanks.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 03-04-2016, 10:38 AM   #7
ceedog's Avatar
I changed mine to HID's & the difference was unbelievable.
The HID kits are more expensive than silver star but the results are worth it.
I got my kits from superbriteled.com. Just give the bulb number in your coach & thry'll send you the correct kit.
The kits take about10 minutes per light to install (depending on whether how you mount the amplifier).
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 03-04-2016, 10:56 AM   #8
It is 9006,there are three versions of this bulb.stock then siver and then there is a very high white light but don't think this is needed
Old 03-08-2016, 04:35 PM   #9
I would like to upgrade our bulbs also. What vehicle did our headlights come from and what year? The auto parts store asked. We have the 2015 38RB.
Thanks in advance!
2015 Berkshire 38RB
2014 Honda CR-V toad
bstnet is offline   Reply With Quote
Old 03-08-2016, 05:20 PM   #10
I found out just a couple of days ago that the Legacy headlights are from a 2007 and newer Chevy Silverado truck. Not sure if the Berkshire us the same or not. There us a very helpful young man at FR named Isaac Montgomery. Isaac is a great source for that kind of information. I do know also that when I looked at the back of the assembly in my Legacy, the replacement bulb number was stamped on the housing. Couldn't bend my head around there, but was able to reach in with my phone and snap a picture of it. Hope that helps some.
berkshire
