Old 06-18-2015, 08:55 AM   #31
I-RV's Avatar
Originally Posted by tnbendr View Post
My front is 10,260 and rear is 17,280 for a total of 27,540. I could not weigh each wheel but feel that I've distributed load pretty even. Are you guys saying that the cargo plus toad weight is gcvw, for the 38A that is 33,000...does that still count if one is not towing (33,000)?
GCVW is the total of the toad (and dolly) and fully loaded motorhome. The 33,000 lbs. limit is because of the Allison 2500 MH transmission. Please note that a full tank of water is one of your largest loads at 833 lbs.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 06-18-2015, 09:07 AM   #32
tmmar's Avatar
This is one of the reasons that I never travel with water in my tank. That is a lot of extra weight to be carrying. I usually have a couple of jugs of water to use to 'flush' the toilet in the event someone needs to use it.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-18-2015, 09:16 AM   #33
I-RV's Avatar
While on the subject of liquid weights; a full tank of diesel weighs approximately 730 lbs.
Old 03-04-2016, 08:31 PM   #34
For those with 38a and have weighed, are you running heavy or does it come from the factory very close to both axle ratings? Looking at the 38a and the Newmar Ventana LE 4002 and CCC is a concern for me, as the weight adds up quickly with water, diesel, and misc stuff.
gtsum2 is offline   Reply With Quote
Old 03-07-2016, 10:29 AM   #35
BamaBob's Avatar
Good Pont Hank - thanks for reminding everyone!
Here are a few weights important to RV'ers:
Diesel - 7.5 pounds per gallon
Water - 8.3 pounds per gallon
DEF - 9.0 pounds per gallon
Black Tank - ~8.8 pounds per gallon
Gasoline - 6.2 pounds per gallon
Propane - 4.25 pounds per gallon
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
berkshire, newbie
