Old 09-12-2015, 06:52 PM   #1
Berkshire 390 Air Conditioner Problem
We have 2 air conditioners with a Dometic Comfort Control Center 2 Thermostat. We lost power few weeks back. Dealer sent inverter off and had it repaired. We out today and found that AirConditioner would not come on and had an E1 error. Was told to reset it by turning all power off (did and error came back) 2-3 mins. Told to buy new thermostat, same problem. any idea's or were i can get a drawing to the system.
stephaniegary is offline   Reply With Quote
Old 09-12-2015, 07:38 PM   #2
Campin Cajun's Avatar
The E7 code is the one I get when I don't have power to the ACs. Are you plugged into 50amp shore power? Have you tried it on generator?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-12-2015, 08:08 PM   #3
It seems you have a lot of electrical issues. A little more info. When you had your 12 volt issue in May did you have the batteries replaced? What happened when this started. Was it right out of the repair shop?
Old 09-13-2015, 09:03 AM   #4
tmmar's Avatar
http://www.dometic.com/QBank/EPiServ...nual_17586.pdf
This is a link to the manual for the thermostat. Did you do a reset of the thermostat after you installed it? Look on page 11 of the manual and it tells you how to re-boot(re-set) the thermostat. Also, you should set the clock. Not setting the clock can also cause issues.
Tom and Margaret
2014 Berkshire 390bh-60
Old 09-13-2015, 06:55 PM   #5
I have tried the thermostat reset by manual. will only flash zone 2, and still do nothing.
Both old thermostat & new one. Not sure why it show 4 zones.
Old 09-13-2015, 06:58 PM   #6
They didn't replace batteries after repair work on inverter, did change them.
The air conditioners will not work on shore power or generator. The thermostat still just does same thing. Does anyone know if there is a drawing of the thermostat to air conditioners online?
Old 09-13-2015, 07:34 PM   #7
jegstrup's Avatar
I received that code when "someone" turned both ac's when we were hooked up to 30a and it tripped the breaker. But the error went away once I reset breaker.
2012 Forest River Berkshire 390FL
2013 Hyundai Veloster
jegstrup is offline   Reply With Quote
Old 09-13-2015, 07:48 PM   #8
So neither the front or rear AC will work?
Old 09-18-2015, 10:40 PM   #9
jmgllt's Avatar
Good info
jmgllt is offline   Reply With Quote
Old 09-19-2015, 12:33 PM   #10
Any update on this issue? Inquiring minds wanna know.
Old 09-19-2015, 03:07 PM   #11
Motodad's Avatar
Try putting both units on high fan speed. See if they come on then. Mine don't like starting up if set to auto.
Motodad is offline   Reply With Quote
air conditioner, berkshire
