Old 09-08-2011, 09:55 PM   #21
marialee-Berkshire410qs
marialee's Avatar
Langeraf, We live in Aberdeen... Where did you purchase your 410qs?
marialee is offline   Reply With Quote
Old 09-08-2011, 10:05 PM   #22
We have a BH, and we bought it used from a guy in NY.
langeraf is offline   Reply With Quote
Old 09-16-2011, 06:27 PM   #23
410 QS 425 2011 Birkshire
410qs
On our way to Lazy Days for a few small problems and then spend the month at their RV park
malewis49 is offline   Reply With Quote
Old 09-17-2011, 09:43 AM   #24
marialee's Avatar
Malewis49..Have a great time!!!
Old 10-05-2011, 04:58 AM   #25
just starting to have problems with the frig the AC side not working but the propain side works fine any suggestions will help
Old 10-05-2011, 10:50 AM   #26
marialee's Avatar
What problems are you having?
Old 10-05-2011, 11:32 AM   #27
on AC will not make ice, will not stay cold, the temp read out(which is a 24hr avg) is 45 to48 degto warm Lazyday has their best person on it 918-637-5957
Old 10-09-2011, 11:18 AM   #28
tmmar's Avatar
Do you have a double door refrigerator in your coach? If so, I have read other posts where the flap in between the 2 doors does not seat correctly and you have to manually put it in the right position. Could be part of your problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-12-2011, 08:10 AM   #29
another day in the shop at lazydays, ref needs a new heat exchanger ,note check your house batteries for water (distilled water only)
Old 10-15-2011, 09:54 AM   #30
new problem with the floor tile cracking, pulled the tile up found water damage from a leak from the refreg outside inspection door had never been sealed
berkshire
