Old 10-19-2015, 10:52 PM   #1
fredhardy's Avatar
Berkshire Awning Remote
Hello all,
After reading about and learning the systems on our new to us 2014 Berkshire 390BH-60, I've only got one system that has me stumped - the awning remote. The awning works as advertised (in & out) but I haven't got a chance to test the sensitivity control in low, med, or high retract. My issue is that I have the remote and I can't seem to set it to work. Is there a switch that needs to be turned on or near the awning motor, or is there a start procedure I need to follow. I read in another FR section to push the start button , wait 3-5 seconds, and then push the in or out button. I followed this process and got nothing. Battery lights up the indicator, so I believe the battery is good.
Any advisements? Not a crisis, but I like stuff to work.
Fred Hardy
fredhardy is offline   Reply With Quote
Old 10-20-2015, 12:41 AM   #2
Battery?
Jeff and Elaine
2011 Berkshire 390QS
2 Lab Dogs-Eros and Star
1 Cockatiel-Lucky
dogsgocamping is offline   Reply With Quote
Old 10-20-2015, 04:38 AM   #3
Fred I believe the switch setting for that is not by the remote but as you walk in the door on the right side where all the switches are there is one cluster there for the awning with these settings.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-20-2015, 05:52 AM   #4
CAT-RN's Avatar
Stored my remote someplace ?? Use it one time to show my son in law I had something he didn't. (Family thing). Not really sure why I would ever need a remote for the awning. The motion control switch should be right inside door with all the other switches. Salesman, lights etc.
Russell
CAT-RN is offline   Reply With Quote
Old 10-20-2015, 06:11 AM   #5
Russell
Russel looks like your son in law may be suspicious. He may have it and you don't. ( family thing ) lol
Joe & Lori
Old 10-20-2015, 07:57 AM   #6
CAT-RN's Avatar
For sure things like are prone to happen around our family !!!
Russell
Old 10-20-2015, 09:16 AM   #7
fredhardy's Avatar
I'll check the battery today. I probably wont use the remote, but heck, I'd like to see it working................
Old 10-20-2015, 04:35 PM   #8
silver's Avatar
Does your remote have the pull up antenna? If yes the battery only last a year in that type. The one without the antenna seams to last several years. I have the antenna and my buddy does not. Special 12V battery. PIA.
silver is offline   Reply With Quote
Old 10-20-2015, 08:08 PM   #9
fredhardy's Avatar
Silver - the remote does have the pull out antenna. It's around 2 years old now, so replacement seems to be in order. Thanks.
Old 10-20-2015, 08:45 PM   #10
Campin Cajun's Avatar
I didn't even realize you could set the wind sensor from the remote. Like others, I used it once to see it work, now it resides in my sock drawer in my S&B house.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-22-2015, 05:48 PM   #11
Russell
Remote for awning...... Sure, I'm laying in hammock napping in the shade. Awning retracts itself because of a small gust of wind. Poof, without getting up I can put it right back out.
BTW, my hat is off the Carefree designers. I have had my awning blown up several times (by a sudden wind gust) so far that the end with the motor slammed against the coach; with no damage whatsoever. Excellent design, IMHO.
On the other side of the coin, I don't think my self retract mechanism works anymore.
Boowho??
boowho is offline   Reply With Quote
Old 10-22-2015, 08:38 PM   #12
CAT-RN's Avatar
Boowho??
Ha. If I needed my remote it would be in the RV. So I have to go get it. So walk past the switch to go get the remote ?? The switch works great for me. I will use the TV remote tho. I did read what you said Boo. You have the remote with you. I never think that far ahead.
Russell
Old 10-23-2015, 09:12 PM   #13
Motodad's Avatar
I bought used. Did an 11 model 390bh have a remote? I didn't get one. How would I know if it's possible to make one work?
Motodad is offline   Reply With Quote
Old 10-24-2015, 07:51 AM   #14
15berkxl's Avatar
Russell
Russell that's probably why FR doesn't supply awning remotes any longer.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 10-24-2015, 10:11 AM   #15
Wayne
Sounds like this might remotely be the reason why our coach didn't have one then for 2014 model. I'm fine with the switch by the door also. To many gosh darn remotes to keep track of.
Joe & Lori
Old 10-24-2015, 11:11 AM   #16
silver's Avatar
Cpbord over the passenger seat has the doghouse for the awning electronics. Open it up and if the hardware is there then a remote will work. I believe it is the white box in the attached picture.
Old 10-24-2015, 11:29 AM   #17
Only have an El Cheapo Flagstaff 5er, but I added a remote for the awning so I could be outside and make sure it doesn't hit something when deploying. The one good thing TURBS has contributed to this FORUM.
Old 10-25-2015, 09:22 PM   #18
Motodad's Avatar
Thanks for the info. I'll have to look at it
Old 10-29-2015, 06:13 PM   #19
fredhardy's Avatar
Update- I replaced the battery and it still doesn't work. Not sure what would be the next step other than parking it in the sock drawer...........
Old 10-29-2015, 06:50 PM   #20
I wonder if there is some kind of sequence or internal micro switches that need to be initialized with the unit. Maybe try their website to see if they have trouble shooting section.
Joe & Lori
awning, berkshire
