Old 08-03-2015, 05:56 PM   #1
Berkshire bay door body screws
I posted on a general FR tech forum, with little response, so I suspect this might be specific to Berk. There are Torx screws on my bay doors that are bigger than a T15 and smaller than a T20. They don't have the security stud in the middle.
Does anybody know where to get driver bits for these? When I brought my 34QS in for warranty service they didn't accomplish any task that involved these screws, so it looks like the dealer doesn't have driver bits either.
gordonsick is offline   Reply With Quote
Old 08-03-2015, 06:33 PM   #2
Campin Cajun's Avatar
Are you sure they are torx screws and not square?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-03-2015, 06:49 PM   #3
Not square. I'm from Canada and am very familiar with Robertson screws, which are the square ones.
Old 08-03-2015, 07:16 PM   #4
I guess I should have typed better. The most common Torx head screws are 6 pointed. The ones on the bay doors are 8 pointed. A #2 Robertson bit will fit it.
Sorry for the confusion.
Old 08-03-2015, 07:37 PM   #5
accumack's Avatar
They look like torx just a shade under t20. a #2 robertson does fit I'm not crazy about the fit. It seems like it could strip easy if it is too tight.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 08-04-2015, 10:26 AM   #6
CC you are correct. A #2 Robertson fits. The same as with the tail light frames.
Paulie Boy is offline   Reply With Quote
Old 08-04-2015, 07:06 PM   #7
A Square bit will work, that's what they are designed for. I had an enclosed car trailer, called the Mfg. square was his answer. Like you, I tried every torx bit in the tool box.
pdqparalegal1 is offline   Reply With Quote
Old 08-07-2015, 11:42 PM   #8
Originally Posted by bruceatlam View Post
I don't find any torx fasteners on my Wildcat, but I do have quite a few #2 square drive fasteners. Maybe that's what you're looking at -- they can look like torx.
Campin,
Thanks.
I thought more carefully about your answer and realized that this is, indeed, an 8-pt fastener that fits a square #2 Robertson driver, so I am able to work with them.
The fastener and driver combination seems to be a combination that uses the worst of the two systems. So, I suspect it is done to work around the Torx and Robertson patents.
The screws look like a #10, and the Robertson world would drive them with a larger #3 driver, not a #2. And the Torx world would use a real 8pt (you may be right that it is 6 pt) driver, not 4 pt.
Thanks to all for your advice.
Old 08-08-2015, 05:51 PM   #9
2011 Berkshire 390BH-60
TaterColo's Avatar
+1. That's what I used to replace one of my latch mechanisms.
TaterColo is offline   Reply With Quote
berkshire, door
