I've had a recurring check engine light. It affects the turbocharger boost when it's on. It comes and goes and will stop after a while. I can't pull a hill with it on. I had injectors replaced and fuel pump work. Can't seem to get this cured. Any help would be appreciated. Bad fuel was the cause for all the failed injectors and pump trouble I was told.
Codes were pulled but were to generic to be any specific help. Just a general reference to fule system. Wandering if anyone else has experienced similar problems. Cummins replaced injectors and some fuel pump work which helped for awhile but the problem is back. I am useing a fuel additive made by cummins so that should not be an issue
