I didn't get pix at the Dealer Expo, but here are some brochure shots and specs that might be helpful. This is an awsome unit for someone looking for diesel power and luxury in a slightly smaller package.
Introducing the all new Forest River Class A Diesel Motorhome, the Legacy. A living experience without equal is around every turn when traveling in a Legacy. Sophisticated décor, sumptuous hardwoods and unsurpassed attention to detail are all Legacy hallmarks.
Your Vehicle Options
Exterior Entertainment Center w/32" LCD TV
Electric Easy-Bed in Cockpit
Residential Refrigerator w/2000 Watt Invertor & Auto Generator Start
Stackable Washer & Dryer (N/A 340BH)
Sealed 3-Burner Cooktop w/Oven
Front Mask Protective Film
RVIA
Exotic Cherry Cabinetry
Brookside Cogna Cabinetry
Maui Interior Decor
Kona Interior Decor
Golden Coast Premium Paint Package
Silver Satin Premium Paint Package
Standard Features
Appliances
(2)13,500 BTU air conditioners S S
Continous gas water heater S S
35,000 BTU furnace S S
30" OTR convectio microwave oven S S
9 cubic ft. Dometic refer with ice maker
Sealed 3-burner cook top
Fan in bathroom
Fan in galley with thermostat control
Washer/dryer prep
Automotive & Cockpit
Freightliner XCS Chassis
Cummins ISB 300 HP Diesel Engine
Allison MH-2500 transmission
22.5" Stainless steel wheel inserts
GVWR, 28,000
GCWR, 33,000
Electric push button shifter
90 gallon, dual fill fuel tank
13 gallon DEF tank
LCD engine message center
Day time running lights
7-Pin tow power connector
18.7 CFM air compressor
Farr Eco-air cleaner
Air filter restriction indicator
Fuel/water separator
Heated air dryer
Automatic, heated moisture ejectors
Power steering
Washer/wiper with intermittent function
160 amp alternator
Two (2) 950 CCA at 0 degree fahrenheit, maint. free
Full air ABS Brakes with auto slack adjuster
Engine brake
Telescopic/tilt steering wheel
Neway air suspension front and rear
Heavy duty front shock absorbers
Heavy duty stabilizer bar
55 degree wheel cut
I-beam suspension with bell crank
Air suspension deflation system
Cross flow, rear mounted radiator
Transmission oil cooler
5 year / 100,000 mile coolant
(some maintenance required)
4-Spoke VIP black steering wheel
Non lighted entry assist handle, black
Electronic cruise control with high idle
Construction & Exterior
Fiberglass front and rear caps
Full body painted exterior (clear coat) 4-color
Four (4) point fully automatic hydraulic leveling system with auto dump
Heated ext/mirrors with integrated Cameras
Frameless dual pane, dark tint windows
Automotive foam and seal, Ziebart undercoating
Electric patio awning
Side-hinged exterior compartment doors with full pass through storage
Bunk bed includes two (2) flip down LCD monitors with DVD and AV input and two (2) wireless headphones (N/A 340KP)
Fiberglass roof
Sliding storage tray
Layered vacuum bonded roof
Vacuum bonded floor with tubular steel frame
Vacuum bonded sidewalls
Gel-coated fiberglass skin
1/2" Structure wood flooring
Block foam polystyrene insulation
Channeled drains for A/Cs
Steel basement construction
Tubular steel front bulkhead
Shower skylight
Rear ladder
82" interior ceiling height
Driver/Passenger Area Standards
One piece windshield
Power front night shade
Manual passenger and driver windows night shades
Fog lights
Dash radio with integrated color back-up and side camera package
Wrap around cockpit with nine (8) gauge instrument cluster
6-Way power driver seat
Leatherite driver/passenger seat
(2)-Cockpit Table/i-Pad/Console stations
Lighted step well
Two (2) Defroster fans with high and low settings
Driver/passenger cup holders
Automotive dash AC/heater with deluxe controls
Entertainment
32" LCD TV, living room
28" LCD TV, bedroom
Satellite TV prep
Cable TV prep
HD antennae with signal strength indicator
A/V distribution for entertainment electronics
Two (2) dash stereo speakers
Sirius satellite radio capable
DVD payer with sound bar
Exterior Equipment
50A service with auto transfer switch & power cord
6.0 Onan diesel generator
Electronic battery disconnect switch
Remote generator start switch (On dash)
LED lighting package
Driv/Pass map lights
Dash, auxiliary start switch
Bedroom individual reading lights
1200 watt inverter/converter
Four (4) six volt house batteries
Two (2) master electric shut off switches
Power entrance step
Patio light
Interior
Vinyl tile forward of the bedroom
Carpeted living room and dining slide-outs
Bedroom carpet with padding
Mattress queen 60x80 312 Coil Everett Slate
Jack knife sofa
Solid surface kitchen & dinette c-tops with flush mount sink and stove cover
Full extension metal drawer guides with ball bearings throughout
Galley storage compartment for range and sink covers
Kitchen pantry (N/A 340BH)
Dream booth dinette with storage underneath
Ducted A/C system
“Soft Touch” padded ceiling
Roller style sun and blackout shades
Bedside wardrobe
Dresser drawers and wardrobe type cabinets
Bedroom, overhead cabinets
Queen bed with bedspread and decorative pillows
Bed night stands
Mirrored medicine cabinets
Plumbing Standard
Variable speed constant pressure water pump
Bath-stainless steel sink c-top mount
Kit/stainless steel sink-undermount
Black water tank flush system
Single lever faucet with pull-out sprayer
Double lever lavatory faucets
ABS shower and walls with glass door
Porcelain china toilet
Whole house filter
Exterior, shower hose
