Old 06-12-2019, 06:34 PM   #1
The Wanderer2's Avatar
Berkshire Emblem
On my 2019 Berkshire 34QS there is an oval Berkshire Emblem on the front generator slide out that is coming loose. It's held on with a rubber membrane of some sort. There is nothing holding it on that I can see from inside the generator slide out. I wonder if it being held by a two sided tape. I'm hoping someone has dealt with this issue and can tell me how to fix it. I was wondering if some 3M spray adhesive would work.
2019 Berkshire 34QS
The Wanderer2 is offline   Reply With Quote
Old 06-12-2019, 07:11 PM   #2
dan-nickie's Avatar
https://www.autogeek.net/3m-auto-tape.html
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-12-2019, 07:32 PM   #3
PPST Wannabe
kenandterry's Avatar
3M tape recommended also. Accept no substitutes.
Just make sure both surfaces are good and clean.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 06-14-2019, 08:16 AM   #4
Went to the storage unit yesterday to take a good look at what was holding the emblem in place. Unfortunately, it has come completely off and was hanging by the wire to the light. When I picked it up the wire broke off. It does'nt look like the wire can be reattached since the led light is incased in the Berkshire Emblem. Now I need to convince Forest River to send me the parts so I can fix it. It looks like the two sided tape was'nt applied correctly at the factory.
2019 Berkshire 34QS
Old 06-14-2019, 08:24 AM   #5
ID:	207313Click image for larger version
2019 Berkshire 34QS
Old 06-14-2019, 09:28 PM   #6
Eagle5's Avatar
Thatís weird. I have the same bus. I thought that piece was screwed onto the body with 4 screws. Iím going on a trip in the morning so Iíll look at mine.
2019 34QS with no ladder!
Eagle5 is offline   Reply With Quote
Old 06-15-2019, 02:49 AM   #7
I found it weird to be held on with just two sided tape. I would of thought there would of been some screws too. Let me know if your's is held on with screws. My coach was made in August of last year, maybe they made a design change as the year went on. I assume that area heats up with the generator compartment being right there.
2019 Berkshire 34QS
Old 06-15-2019, 05:06 AM   #8
Eagle5's Avatar
(donít mind the bugs) but mine has 4 Phillips screws attaching it
Old 06-15-2019, 07:11 AM   #9
I guess they did make a design change or made that fix at the dealership after delivery from the factory. I'm curious if there are any other owners of a 2019 with the four screw fix on here?
2019 Berkshire 34QS
Old 07-03-2019, 10:05 PM   #10
Dijoeboss's Avatar
Berkshire Emblem
If you use 3M VHB ( very high bond ) 2 sided tape, make sure you also purchase some activator ( comes in a package that looks like a alcohol wipe or glasses lens cleaner ) clean the surfaces, apply the activator to the surface of the coach that the tape will stick to, once you stick it on, itís not coming off!! This 3M activator can be purchased at auto parts stores, they may have to order it for you. The activator is the key factor to the 3M tape making the stick!! You get ONE shot of sticking it on straight, seriously, once it makes contact, you donít get a 2nd chance
Dijoeboss is offline   Reply With Quote
Old 07-03-2019, 10:09 PM   #11
Eagle5's Avatar
Or just use a couple of self tapping screws like FR uses for these now. Zip Zip done deal
Old 07-04-2019, 04:47 AM   #12
I'm taking it in for warranty work later this month and they are going to replace the emblem at that time. It needs to be replaced because the wires that power the light broke off when the emblem fell off. I contacted Forest River and they are sending a new part to the dealer to install when I get there. I'll let you know exactly how they replace the new emblem after that. I was going to replace it myself until I noticed that the wires broke off from inside the emblem and left nothing to solder the wires too.
I have the coach at Freightliner now for a recall that affects the tail lights. My left brake light went out. They need to replace a module for the rear lights.
2019 Berkshire 34QS
Old 07-04-2019, 04:58 AM   #13
Eagle5's Avatar
You referring to their place in gaffney SC? Iíd like to go there for a service and just to check out the place. How they treating you?
Old 07-04-2019, 05:12 AM   #14
Me too, no I'm having it done at a local Freightliner service center.
2019 Berkshire 34QS
Old 07-04-2019, 10:27 AM   #15
Dijoeboss's Avatar
Berkshire Emblem
[mnvfftefuioptedvb. Jujube
Old 07-05-2019, 11:40 PM   #16
omahagirl's Avatar
We went to Gaffney SC for the two day camp Freightliner class. The classroom is in the service center bldg. Very impressive shop. Call ahead for appointments.
omahagirl is offline   Reply With Quote
Old 07-06-2019, 05:05 AM   #17
Any idea how far in advance you need to call for a appointment?
2019 Berkshire 34QS
Old 07-06-2019, 06:30 AM   #18
omahagirl's Avatar
Not sure Iíd just call and ask. I know they try to accommodate drop ins but when we were down there they had to say no to some people they do have spaces some with electric and a smaller nice lounge you can even bring in your dog leashed to hang out. Time it good and you can also take the tour of the factory, different location must be in that office prior to 10am M-F
Old 07-24-2019, 06:12 PM   #19
RKNOLA's Avatar
That's a cool looking Berkshire emblem! I wonder if Forest River would sell one of those aftermarket........ probably only slightly less than a small foreign car I'm sure!!
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 07-25-2019, 07:44 AM   #20
I have no idea of the cost but they fixed my emblem earlier this month. The one sent by Forest River to fix it was found to be damaged when opened. Forest River had one brought over from the factory the same day and the problem was fixed. It was replaced just like the original with two sided tape and no screws. It looks really good. We'll see how it holds up during our three month trip out west starting next week.
2019 Berkshire 34QS
berkshire
