01-12-2012, 07:17 AM
berkshire generator wont start
On my 2010 390bh, while in storage, my house batteries drained. I attempted to start the generator and it would not turn over(not surprising). I plugged in the unit, left it for 2 weeks, came back to start the generator, and still nothing. I figured with full charge the generator would turn over. Are there any simple steps to troubleshoot this issue? I'm a recent graduate from gas to diesel and I never had a dead battery on my 2008 Damon.
01-12-2012, 07:28 AM
2011 Berkshire 390bh
Did you have all the battery disconnects turned back on? We leave ours in storage and leave it plugged in, but the battery disconnects turned off. Before I start it back up I turn all the disconnects back on. You may need to attach a trickle charger to the batteries to get the generator going again.
01-12-2012, 10:39 AM
you may need to hold the starter switch down for about 10 seconds you'll hear a clicking noise then it will turnover and start donot crank for for more than 10 to 15 seconds it will burn out your starter. hope this helps.
01-12-2012, 02:51 PM
I held down the starter and got a faint click click click. Even with the unit plugged in it may not have charged the batteries enough. They appear to be jell type(no water). I will try to find a 6volt charger. Also, I just found the battery cut off switch in the battery bay. That may have lead to the parasitic drag. I have books ten inches tall to learn about all of the systems. Thanks a bunch
01-12-2012, 04:38 PM
Berkshire 390QS
Thought I had the same problem, check thebattery level and nothing until I figured out while some service at the dealer, they had turned off the master switch by the door. surprize, everyting worked once the unit is turned on. sometimes we all over look the little things. best of luck and happy camping.
01-12-2012, 07:03 PM
If it is a gel type battery make sure the charger u use is capable of charging gel batteries. Could ruin your battery.
01-12-2012, 08:14 PM
Thanks. I will look into the battery charger issue. I had hoped by plugging the unit in, the batteries would be fully charged. I found the cummings generator book and am working my way through it.
01-12-2012, 08:33 PM
The charger I have will charge Std. AGM or Gel. 6 or 12 volt
01-13-2012, 08:46 AM
What brand and model charger do you have? Is it one that you can leave plugged in without worry of over charging. When I store my unit, I may not see it for months.
01-13-2012, 09:32 AM
It's a Schumacher XC10 10/6/2-Amp Battery Charger. $40.00 at Walmart. You can leave it on as a tender. It electronicly monitors battery. Next model up XCS15 has a LED read out monitor, Is's $50.00
Jim
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 621 |
| 126 members and 495 guests |
| Barr4, bashby17, Bigjimt, BigR, bikendan, BlakeB, bob7794, boubou, Buffalohunter, Busman1947, Cafjackracing, campfirefun, CampinQueen, Capsfloyd, cardinal4fun, Cascade Bob, cgreen1509, cgsparks1, chof16, Cincy6, COcamper, cory1, Cowracer, cstover, Curiosity, dansa122, dashonthedash, dasimser, daveinpickerington, davidjb, dec1952, dezolen, dfrauhiger, djorgensen3, donn, dotsonjc, dretired, dtb7811, dunnnc, EL99jl, f1100turbo, Falcon35, Filthy Beast, Gene Ross, geo, go6car, gredmer, gregm59, gregory, herdrn, herk7769, hokiecampers, holymoly, Hoo Dad, hotrodj125, JAJ73, jamesroadking, Janet H, jar3316, JENSENRVDirect, JFM-jr, JJones, jlpurdy, jmswms, johnnypal, judy3972, kegoneill, kixonrt66, KKapa, lazyb1626, leadfoot, lindy, lowbubba, LuckyMcBRIDE, Mark S, Maxxmarc, mhbandy, mike54, milw156, mraynie, mtnguy, mtofell, myredracer, NeilM108, ng2951, Papa Roo, papap, Phil57, pick, Piston, Playtime III, punkaccountant, rbrandon, realebill, rerger, RGH, ronhanson, rwzahm, sabre5er, savdog, SDENN4281, shane1234, shrimper, silverwing, sledhead77, Snowsail, tallens, Terier, tmiller, tmmar, Tom47, tracetrimble, Traci, travyp, treadwelll, Triguy, T_LMurphy, ubercamper, vc17, Vette4trcr, vp22er, VTX Al, Warrior, wfmdfm, whj77372, wnytaxman |
| Most users ever online was 996, Today at 11:04 AM. |
