Old 07-21-2012, 06:51 PM   #1
Berkshire gvw
I'm a little confused on what Forest River was thinking when the set up the Berkshire 390RB 340. As I look at the front axle weight it is 10410 lbs drive is 17500.
I have normal camping stuff clothing groc. full fuel quarter tank fresh quarter tank lp. And I had almost full gray and black tanks. I stopped to get weighted and front is 11040 rear 17720 total is 28760. I'm 850 lbs over weight with a normal load on board. The worse is I'm over 630 lbs on the steering axle. Towing a enclave that weighs around 4900 I will be over about 800 lbs. I know I didn't buy the biggest baddest MH but really what am I missing here we do not have a full basement and have done nothing to the MH that would add weight. I will be talking to FR Monday AM to see exactly what I am supposed to to do here. I can't aged 800 lbs and still have anything left to camp with. If it was the Enclave pushing us over weight I would understand and would not be as concerned but most of my issue is on the front axel. Anyone have any ideas?
Old 07-21-2012, 07:56 PM   #2
Dave_Monica's Avatar
I don't understand why you would be driving around with full gray/black tanks...that's 866 lbs there.
The towing of the toad wouldn't impact of the MH's axle weight unless you're towing using a dolly instead of 4 down in which case the dollies tongue weight would be on the rear axle. The limit of the toad is the MH's GCWR which is 5000 lbs more than it's GVWR.
Dave
Old 07-21-2012, 08:22 PM   #3
Thanks Dave I traveled with full black and gray tanks becouse I could not get to the dump easily on Sunday and Friday we were heading to a full hook up and decided to dump then. I dumped my fresh tanks so compensate for that and considered it a close wash. I like to have some fresh water with me and some times I need to carry a full tank when dry camping. It seems like that's not to much. I understand the toad weight being part of the GCWRand the toad will work fine. I weighed the MH with out the toad. So I guess the answer is carry min fresh water and deal with that. I almost never have anything but empty gray and black.
Old 07-21-2012, 08:39 PM   #4
Does anyone know the unloaded weight of the Berkshire 390RB 340hp. On line it is listed as TBA.
Old 07-21-2012, 08:58 PM   #5
Phil...there's no sticker that refers to cargo carrying capacity including fresh water for your Berkshire?
Dave
Old 07-21-2012, 09:30 PM   #6
Dave not that I'm aware of I have the GVW listed at 27910. I was wondering what the empty MH off the lot weighs. I would like to know how much "stuff" we have put in that we felt we couldn't live with out. If I bought a new coach today I would take it to the scales before I put anything in it. All the FR web site says is TBA.
I can live with the water issue and you had a good point about the B&G tanks and I always run empty. I just thought that I could run with more fresh water. I just need to decide on priorities in regards to loading. I am at a rally with a local chapter of FMCA and most everyone I talked to had a much larger cushion between the weight of their MH and there GVW
Old 07-22-2012, 09:57 AM   #7
tmmar's Avatar
Do you have tile floors or linoleum/carpet? The tile will add a lot of weight and cut down on your carrying capacity. That is one reason that I am happy I didn't get tile.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-22-2012, 10:17 AM   #8
I have tile floors. It would be nice to know what they weigh and if that makes the GVW that tight because of that why would FR offer that as a option?
Old 07-22-2012, 11:19 AM   #9
tmmar's Avatar
Each chassis has a specific weight rating and I think that FR just puts in each coach what they feel the customer is looking for. As long as it doesn't go over the chassis manufacturers specs when it leaves the factory, they leave it up to the customer to deal with the GVW and only carry what they can up to the specified weight limit. JMHO.
Tom and Margaret
Old 07-22-2012, 04:34 PM   #10
2011 Berkshire 390BH
Superchief's Avatar
Phil57,
I understand your frustration. I have the same unit and I was surprised the first time I had it weighted. I was over. I dumped fresh water to get close. I then took out some items that I had loaded. Reweighted and was a couple of hundred pounds under. I keeping looking for more information on how Forest River loaded it out and did they increase the weight carrying capacity over what Freightliner posted, i haven't found anything. I have driven 10,000 miles in the past year with the unit and have not had any issues. I believe I am a couple hundred pounds over at times. I continually monitor the tires pressure and temp and have continually been fine. I would like to know what answer you get from Forest River.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
berkshire
