Old 06-05-2014, 08:00 PM   #1
JTN8's Avatar
Berkshire preventative maintenance
So the end of July will be 1 year since I've owned my 2014 berkshire 390BH and I was wondering what y'all do for preventative maintenance, fluid changes etc... I looked on freight liners web site and I saw the 6 month inspection sheet and 12 month inspection sheet. I called my local freight liner service center and they quoted me $350 for an oil change, chassis lube and full inspection. I also called my local cummins service center and they quoted me $175 for the oil change, $50 for the fuel filters and another $50 for the motorhome chassis lube. I've changed the oil my self for the generator and that was easy but the engine makes me a little nervous. So I was wondering, are these prices average and is any of the Preventative maintenance things easy to do your self or should I bring it to one of the service centers? Obviously the freight liner inspection sheet is long and in depth and pretty sure I can not inspect all of the things on there so my other question is should I stick with freight liner service center or use cummins service center when doing the inspection? Thank you in advance for any of your experiences with the above questions.
Jason
Old 06-05-2014, 08:45 PM   #2
Berkshire 390QS
NO3putt's Avatar
For us we take to an authorized Frightliner/Cummins dealer. (They are both) Every year we have the following:
Oil change, engine & generator
Fuel filters
Lub
Chassis inspection, brakes checked, water tested,
For around $450
As needed:
Air filters
Air dryer serviced
What ever is listed in manual based on miles
They found a front brake seal leaking.
They found rear brake pad chunking
A good dealer is the best thing you can find.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 06-10-2014, 09:33 PM   #3
JTN8's Avatar
Fuel filters
Lub
For around $450
As needed:
Air filters
Air dryer serviced
Thank you for the info!! Sounds like the pricing is about the same and I think I should stick with freight liner even though a little bit more than cummins, I want my chassis inspected properly. Thanks again!
Jason
Old 06-11-2014, 12:12 PM   #4
Mmnsc's Avatar
Have you thought about having you service done at the FL facility in Gaffney SC. They do great job, know what they are doing and provide overnight parking with hook ups. Also a great opportunity to attend camp freightliner. Just my opinion
Mmnsc is offline   Reply With Quote
Old 06-11-2014, 12:33 PM   #5
JTN8's Avatar
Little far for me for service, I have a Freightliner service center close to my house. I am planning on attending the camp in October though, but don't want to wait that long for my service. End of July will be one year and I'm just under 6k on mileage right now.
Jason
Old 06-11-2014, 07:26 PM   #6
dan-nickie's Avatar
I thought my book said the first service should be at 6 months?
Are you guys skipping that one?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-11-2014, 07:29 PM   #7
JTN8's Avatar
I did see freight liner has a six month inspection on the chassis, but the first service for oil and oil/fuel filters are 1 year, unless I read it wrong.
Old 06-11-2014, 08:47 PM   #8
dan-nickie's Avatar
So, did you get an 'inspection' at 6 months.
What does everyone do at 6 months if anything.
My 6 months is coming up but only have about 2000 miles.
Does it affect warranty?
Dan
Old 06-11-2014, 08:48 PM   #9
2011 Berkshire 390BH
Superchief's Avatar
FL changed the 6 month to 1 year (per Mike (Instructor) at Freightliner Camp).
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 06-11-2014, 08:55 PM   #10
JTN8's Avatar
I did not get one at six months, looked at the inspection sheet on freight liners web sight and it was the same as the one year. I figured I'd take care of it all at the one year mark when I needed all of the fluid and filters changed. I did change the oil and filter myself on the generator once I hit my break in hours though since cummins wanted $100.00 to do it and it cost me less than $25 to do it myself... Very very easy if you air up the bags and crawl under the generator when pulled out. I'm sure I could change the oil myself in the engine too, but not sure about the fuel filters..... Not sure how hard they are...
berkshire, maintenance, vent
